Old 08-14-2003, 08:45 PM
CRXsk8er CRXsk8er is offline
Send a message via AIM to CRXsk8er
need sum help with my b16
well my b16 arrived this morning at 930 and i got home from school and i was checking it out i took the spark wires out and there was like oil in it but it wasnt oil i smelt like a fluid but it was like clear almost just dirty??? does anyone kno what it could be i took the valve cover off and i sucked it all out but im not sure what it was it looked like dirty water.....anyone got any idea like what i should check??
thanks......Chris
Old 08-14-2003, 10:55 PM
91zc 91zc is offline
It is just water. When they clean the motors they spray them off with high pressure water and the water tends to get into places it shouldn't. As long as you are sure you sucked all the water out of each cylinder you should be ok. Water doesn't compress and therefore if there was a lot in your cylinders and you tried to start it the engine could be damaged.
91 civic 4dr
b16a
14.8@94
Old 08-15-2003, 02:25 PM
Re: need sum help with my b16
k thanks man cause i was scared there what sumthing wrong but i sucked it all out and im goign to fill my compressor upand blew it out just to make sure thanks man.....
need help with b16 89 civic si swap Justo88 JDM Motor & Parts info/chat 1 06-05-2007 02:02 PM
Hey guys i need sum help 4-THGENH24LUDE '88 - '91 Civic | CRX | Wagon | Shuttlee 19 10-09-2004 12:21 AM
help with b16 swap need parts and help 92b16si Engineering/ Technical 1 12-08-2003 01:19 AM
hey i need sum help on expert map for ver. 1 flame_flare Other Games 3 10-02-2003 11:53 PM
need sum help finding a car! Evils_Import Street Racing 20 12-22-2002 11:58 AM
