Old 08-14-2003, 11:41 AM
cowboybeebopfl cowboybeebopfl is offline
Send a message via AIM to cowboybeebopfl
1989 dodge caravan starter
i am having trouble with my 1989 dodge caravan. when i turn the key, it just clicks. sometimes it took one or two trys to get the engine running. sometimes about 50. but now its not starting at all. i dont want to go drop a bunch of money on a new starter if its something else thats cheaper. please help.
Old 08-15-2003, 11:08 PM
pcv pcv is offline
Get a test light. Connect one end to a good ground and the tester end touch the starter trigger wire, small single wire. While you are doing that, get someone to attempt to crank the vehicle and watch the test light. If it lights, replace the starter. I know it is the starter, but confirm it with the above test. Good Luck.
NOTHING LIKE AN OLD CAR.
Old 09-13-2003, 06:15 PM
Entreri33's Avatar
Entreri33 Entreri33 is offline
Send a message via ICQ to Entreri33
Its the solinoid, its shot. Its part of a new starter assembly. The good part is you can at least get core value for your old starter.
Had 2 cars totalled in 2 years.... searching for a new toy. Maybe another RX7(w/20b) or a 280Z(w/rb26dett)
I had...
87 RX7 sport (drove it for years)
01 Firebird
Need a new project car.
the 5th column will be the death of the american dream.
Old 11-14-2003, 09:35 AM
yale329 yale329 is offline
Re: 1989 dodge caravan starter
Check and clean your battery cables and starter connections first. ***Make sure to disconnect the battery when inspecting starter connections***.
Old 11-05-2004, 02:47 PM
DAVE K DAVE K is offline
all the above sounds good,but one other thing if you
have no juice at all you might check the second wire coming off of the positive batt.cable for a blown inline fuse or corrosion(but that is if there is no power at all)
