Old 08-14-2003, 08:03 AM
4g4d_getone's Avatar
4g4d_getone 4g4d_getone is offline
d16a6 ecu
i got a dx motor, a crx si mpfi, si distributor, and my wire harness is changed to controll the mpfi. i just got a hold of a 91 crx si ecu and i put it in the other day and my car was hesitating from 1,000--3,000 rpm but then after 3,000 it just picked up. what do i got to do so that i can switch my dx ecu to a si ecu?
Y LOOK FAST WHEN YOUR NOT?????????
Old 08-14-2003, 08:12 AM
marked001's Avatar
marked001 marked001 is offline
Moderadur
Send a message via AIM to marked001
..what do you mean switch your dx ecu to a si ecu? like literally change something inside the ecu? that's not gonna happen... I'm sure there's some other reason for the bogging besides the ecu.. it could be alot of things..
SOLD!
Old 08-14-2003, 08:15 AM
naw i mean take out the dx ecu and put in the si ecu. i called this shop where i get my car worked on and he said that i can put it in but i dont know y it makes my car hesitate from 1-3k, so i just took it out and put back the dx ecu
Old 08-14-2003, 08:32 AM
marked001's Avatar
Moderadur
..and the car runs ok with the dx ecu, yet you changed the wiriing?
SOLD!
Old 08-14-2003, 08:38 AM
sastanley's Avatar
sastanley sastanley is offline
AF Premium User
Send a message via AIM to sastanley Send a message via Yahoo to sastanley
Question WTF?
yeah man...fill us in...I am surprised the car runs with MPFI wiring on the DX ECU.
-Shawn
'91 Civic DX sedan
DOHC ZC, I,H,E, urethane bushings and mount inserts, rock chipped hood, some rust, stock steelies, nice comfy Integra seats, and the A/C works! What else could you want from an 18 year old car with 241,000 miles? Working on getting the Si tranny in now
Old 08-14-2003, 08:49 AM
yeah man see i dont know how to do do all the wiring and shit so i sent my car to a performance shop here in orlando where they just work on honda and acura's and they changed my wiring harness to work with the mpfi. so i figured since i got the si mpfi i should be able to use the si ecu but maybe i will just take the computer to the shop and have them do something so it will work right.
Old 08-14-2003, 11:27 AM
91civicDXdude's Avatar
IMPOSSIBLE.
If you did the wiring right, there is NO WAY IN HELL a DX ECU will run an MPFI setup. I know, because i've tried it. The DX ECU makes the car run on two cylinders and will sound like TOTAL ASS.
Old 08-14-2003, 12:19 PM
sastanley's Avatar
AF Premium User
Thumbs up exactly
Yeah...that is what I was thinking, cuz the DX ECU will only fire two of the 4 injectors...
Here is a link to the DPFI to MPFI wiring...maybe you can double check your shop's work.
http://tech.hybridgarage.com/tech/4g...-zc-wiring.htm
-Shawn
'91 Civic DX sedan
Resetting ECU- 1995 Toyota Camry V6 XLE Techniker Camry/Camry Hybrid/Vista 1 07-07-2010 08:42 AM
avoid REV Limiter for 4AGE- BT ECU-6speed MT Petroahorro Sprinter 0 06-18-2010 09:22 AM
avoid REV Limiter for 4AGE- BT ECU-6speed MT Petroahorro Sprinter 0 06-18-2010 09:21 AM
Gear selector error and other ECU mysteries jarl Trans Sport 5 05-02-2010 06:33 AM
Flash ECU, will the car start without? schreib Rodeo | Passport | MU 1 03-15-2010 08:09 PM
