Old 08-13-2003, 06:55 PM
petereggy petereggy is offline
Putting a 400 into a 1980 Firebird
I have a 1980 firebird now with a 301 and a T350 tranny, Im wanting to put a mid 70's 400 with a T400 tranny into it. Will all of the engine mounts and tranny mounts line up? and is there anything else that I will need to do? any help is much appreciated
Old 08-14-2003, 01:07 AM
bking120's Avatar
bking120 bking120 is offline
Send a message via AIM to bking120
the engine will mount just fine the tranny should as well i did the same thing in a 80 ta i had it was a long process but worked great and btw u might want to update the exhaust if u have not done so
Old 08-14-2003, 01:58 AM
yah im planning on building the engine into a half day to day and half drag car
alright so I shouldnt encounter any problems doing this?
Old 08-14-2003, 01:36 PM
bking120's Avatar
u shouldn' have any problems its not even a tight squeeze u r going to need some new bypass belts well i did i took out my ac since it didn't work and i put on a new fan u might need a bigger radiator i found one at a junk yard and they gave it tp me 3 core might work i had a 2 so i put a 4 in it if u have a 2 u need a bigger one other than thateverything worked.
Old 08-15-2003, 05:12 PM
what would i need bypass belts for?
Old 08-15-2003, 06:31 PM
TheRealShiz TheRealShiz is offline
Send a message via AIM to TheRealShiz Send a message via Yahoo to TheRealShiz
more horses.
Reppin the D's..
Old 08-15-2003, 07:34 PM
how so?????
Old 08-23-2003, 02:18 AM
would it work with my current T-350 as well?
Old 08-24-2003, 02:11 AM
bking120's Avatar
your 350 t should bolt up to as well.. the less belts running = less strain on your motor= more hp.
Old 08-24-2003, 02:34 AM
well it dosent have ac so the only other thing to bypass is the smog pump which ill take apart and then just leave the pully to spin freely
Old 08-25-2003, 02:16 AM
bking120's Avatar
i would just bypass that pully all together there pretty cheep for a bypass belt i think they were like 4 dollars a piece less pullys running he better pluss smaller belts are better as well. let me know how this process works out
Old 08-25-2003, 02:18 AM
i will
but the pump still needs to spin cause if air care inspects the engine compartment i will fail it on the spot
and i just hate aircare cause if u dont got the cats and that stuff it dosent matter what comes out the tail pipes you still fail
