Old 08-13-2003, 05:03 PM
Sleeperswift Sleeperswift is offline
Clutch Pedal friggin stiff
i don't know if this is normal or not, but the clutch on the 91 civic se i am going to buy is really really stiff. like leg about to die stiff. Also, is it really normal to slip the clutch at 5500rpm and not squeak the tires. Looks like its time for a new clutch
1985 Nissan 300zx Turbo
Soon to own a 1991 Honda Civic SE
Old 08-13-2003, 10:55 PM
bump, is this normal
Old 08-14-2003, 01:09 AM
BullShifter's Avatar
Re: Clutch Pedal friggin stiff
If you slip it, no it wont spin. Dump it @ 5500rpm & you should spin. There is no reason to use a very stiff clutch unless over 250HP. I tore me up some tires yesterday on the Si. Nice long burn-out w/ e-brake 1st, 2nd, & held 3rd until the damn temp starting going up.
Old 08-14-2003, 01:24 AM
XxLuckyLisaxX's Avatar
XxLuckyLisaxX XxLuckyLisaxX is offline
Send a message via AIM to XxLuckyLisaxX
i got a question, if your clutch is too stiff can you fix that, make it easier to push in, like somehow you can adjust it, theres such a difference between my si and dx, when i drive the dx now my leg gets sore
Keep it real, and share the knowledge.....
Say NO to Primer!!
Old 08-14-2003, 01:44 AM
CRX89 CRX89 is offline
Same here std is so smooth but my Si is a pain to push in. I know it got a new clutch before i bought it. Im the only owner to use the clutch in it now. Is it possible that maybe mine and these other si have worn clutch cables???
Old 08-14-2003, 07:57 AM
4g4d_getone's Avatar
4g4d_getone 4g4d_getone is offline
yeah it was the same thing with mine and u have 2 pull the clutch cable a little bit from the engine bay
Y LOOK FAST WHEN YOUR NOT?????????
Old 08-14-2003, 10:30 PM
Make sure the clutch cable is good - lubed/ajusted - not binding
Clutch pedal adjusted & lubed
Besided that you really cant change the stiffness by adjusting, only replacing.
Old 08-15-2003, 10:10 AM
sastanley's Avatar
sastanley sastanley is offline
AF Premium User
Send a message via AIM to sastanley Send a message via Yahoo to sastanley
the "stiffness" of the clutch should be determined by the fingers in the pressure plate...higher performance clutches have stiffer fingers to hold pressure on the flywheel better....thus the pedal will feel stiffer when you push it in. Otherwise, you may have some binding in the cable and that could be a bad thing. I currently have some binding where my cable goes thru the firewall, and it creaks and makes noise..I need to fix it before it breaks
-Shawn
'91 Civic DX sedan
DOHC ZC, I,H,E, urethane bushings and mount inserts, rock chipped hood, some rust, stock steelies, nice comfy Integra seats, and the A/C works! What else could you want from an 18 year old car with 241,000 miles? Working on getting the Si tranny in now
