Go Back   Automotive Forums Car Chat > Ford > Bronco
Old 08-13-2003, 03:44 PM
Bellis Bellis is offline
problems running
I have a 1989 bronco ii and it has problems running.
Usually it will start right up. But after I drive around for 5 minutes or so and I let up off the gas. It just suddenly dies. And I was at McDonalds the other night and I had to keep my foot on the gas at the drive through so it wouldn't die. But after waiting for 10 minutes it died anyways. And then I have to wait roughly an hour before it will start up again after that.
I just got the battery replaced today and it's still doing the same thing.
Any idea what the problem could be.?
Old 06-13-2005, 03:00 AM
Ree86bronco302 Ree86bronco302 is offline
Have you checked your fuel filter?
Old 06-23-2005, 09:21 PM
dpesposito dpesposito is offline
Re: problems running
check your parts on your belt line. A frozen air pump, or ac unit for instance will not immediately show you problems, but will slow down the belt line enough that the engine will stall. It may start when cold, but then when the frozen part heats up, it begins to bind.... an most times you will not see smoke
Old 06-27-2005, 12:16 AM
Truck Truck is offline
Might as well check the exhaust for back-pressure problems.
2001 Cavalier - left front headlight problem/running light problem bbucklew93 Cavalier Problem Diagnosis 3 05-23-2008 10:08 PM
I'm baffled, problem running right off the bat but it runs great afterward... help! Thor06 Eclipse Problem Diagnosis 8 08-02-2007 05:45 AM
89 TBI problems. Running bad TopDogg C/K 11 05-26-2006 11:00 PM
89 dodge b250 problem running possible fuel injector? stamar Ram Van 11 04-24-2006 01:39 PM
will my 91 240sx have any problems running w/o the catalytic converter on? prince vegeta 2002 1 04-20-2005 06:24 PM
