Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 08-12-2003, 11:03 PM
caper caper is offline
concerning turbos...will s15 turbo on s13
hey guys...i was just curious...i forget which turbos are on which but will the s15 or s14 factory turbos bolt directly on the s13 redtop sr20det motor? if so do you guys think if i could swap turbos from my motor distributor and get the s15 turbo to come with my s13 engine package a better deal than factory s13 turbo?
thanks for the reply
Old 08-13-2003, 08:05 AM
turbo2nr's Avatar
turbo2nr turbo2nr is offline
Send a message via AIM to turbo2nr
s-15 t-28
s-13 t-25
the t-25 and the t-28 both dosn't make more then 18psi, 16psi for the t-25.. i think i directly bolts up you might have to geta new turbo flang tho.. not to sure.. i personally would say stick with the t-25 and the when you upgrade upgrade to something good!
1
Shift_BOOST
97 s14
Old 08-13-2003, 10:30 AM
JDM0WN3Z JDM0WN3Z is offline
Flange is the same and will bolt up.
The angle of the intercooler pipe is different. It closely resembles the one off a CA18DET. You can get adapter plates in Japan to vary the angle. Over here, I don't know. You might have to custom it.
Old 08-16-2003, 12:27 PM
BOOSTD's Avatar
BOOSTD BOOSTD is offline
I personally think its a very worthwhile upgrade if your on a budget as the S15 turbo is a roller bearing type and the S13 turbo is plain bearing. A friend of mine bolted the S15 T-28 to his S13 Silvia and is running a measly 14 psi and the car is significantly quicker. Also the S15 turbo is a much stronger item.
Compressor Map for s15 turbo Chiquae07 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 1 10-04-2006 10:52 PM
t25 + rb26 turbo = s15 turbo? Skylindrftr Technical 0 03-12-2006 06:02 PM
S15 Turbo upgrade '94ZENKI/S14DRFTr\ Technical 7 02-23-2006 06:40 PM
Lookin for your old s15 turbo tyko909 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 0 09-27-2004 03:47 AM
