Old 08-12-2003, 07:50 PM
blade34609's Avatar
blade34609 blade34609 is offline
Car runs, but doesnt idle right
Hi,
I finally fixed it today where the car wouldnt rev past 3000 RPM.
It turned out to be a broken injector wire.
soldered and heatshirnked it and it works fine.
Only problem is the idle.
It idles at about 1500 RPM.
I tried adjusting the idle screw but it doesnt slot the RPm down any bit.
All I can do it make the RPM idle higher, but no lower than 1500.
I know out cars should idle at only about 800 RPM.
My check engine light is also still on.
Any help would be appreciated.
Thanks
1990 Honda Civic LX
5 Speed
1.5 Liter SOHC
K&N Cone Filter
APC Short Shifter
1988 Honda Civic STD Hatch
D16A6 Si swap
DX 5 Speed Tranny
90' CRX Si Gauge Cluster
Accel Performance Wires
Old 08-12-2003, 10:49 PM
blacksheep blacksheep is offline
Send a message via Yahoo to blacksheep
reset your ecu if u havent already by deisconnecting the battery a taking the hazard fuse out, and see if theres still a check engine light
it better get me to wyoming
Old 08-13-2003, 02:23 AM
Setanta's Avatar
Setanta Setanta is offline
Send a message via ICQ to Setanta Send a message via AIM to Setanta Send a message via Yahoo to Setanta
Any one of a dozen vacume hoses might need replacing, but more likely it's the fast idle valve or even the throttle position sensor. A case of replace for the former and get a new throttle body with TPS on it for the latter.
'99 PY DC2R
'85 BBS BMW E30
RIP '90 JDM EF9 Civic SiR
www.performanceforums.com
Old 08-13-2003, 04:50 PM
blade34609's Avatar
Aiight
But u guys dont think it could have anything to do with the ECU?
1990 Honda Civic LX
5 Speed
1.5 Liter SOHC
K&N Cone Filter
APC Short Shifter
D16A6 Si swap
DX 5 Speed Tranny
Old 08-13-2003, 05:40 PM
Setanta's Avatar
Nope - it's a sealed unit with a fixed program
'99 PY DC2R
'85 BBS BMW E30
Old 08-13-2003, 11:38 PM
blade34609's Avatar
But i did mess with the ECU and change the B2 pin to B10.
But then I decided against it and put it back in B2.
What if I didnt get it seated properly?
Could that cause it?
Im pretty sure I put it back in right, it wont come out.
Thanks
1990 Honda Civic LX
5 Speed
1.5 Liter SOHC
K&N Cone Filter
APC Short Shifter
D16A6 Si swap
DX 5 Speed Tranny
