Old 08-12-2003, 10:08 AM
CE9A CE9A is offline
Unhappy stock fuel/ignition maps
can anyone please help me out? i need the stock ignition and fuel maps for the eclipse's 4G63.
Old 08-12-2003, 11:11 PM
kjewer1 kjewer1 is offline
AF - Advisor
I have them. I'll try to get them up when I get home
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 08-13-2003, 01:36 AM
RockinWRX RockinWRX is offline
Send a message via AIM to RockinWRX
Whatsa matter? Got lost? Delete the AEM's memory?
'90 Galant GSX , AWD , 5spd. Waiting on an engine swap.
'03 WRX wagon , AWD , 5spd. Waiting on a paycheck.
Old 08-14-2003, 09:10 AM
thanks alot 95 GSXracer! appreaciate it very much.
no i din delete the memory RockinWRX, i need the stock eclipse maps to use on a JDM 4G63 from a Galant VR-4. i tried using the maps from the EVOs(I-III) but they don't work. say, know any modified maps what wil work?
anybody knows how to remove/extend the rev limiter?
Old 08-14-2003, 09:12 AM
AF - Advisor
Hmm. Perhaps I'm missunderstanding what you need. I know what the ECU uses at full throttle at over 2.1 grams per second for timing and fuel enrichement vs rpm, but I dont have any actual maps for the aem or other standalone.
Kevin Jewer
Old 08-16-2003, 09:03 AM
Re: stock fuel/ignition maps
i need the stock maps to try on a re-chiped VR-4 ECU. not running any stand alone yet.
Old 08-21-2003, 08:06 AM
uhm.......95 GSXracer.....still there?
Old 08-23-2003, 12:23 AM
AF - Advisor
I've been doing this a long time, but I'm still not sure what the hell it is you're looking for I have the max airflow curves for timing and fuel enrichment, for 2g, thats it. I have a feeling thats not what you are looking for....
Kevin Jewer
Old 08-24-2003, 11:38 AM
urm, ok ok let's see,...ok the fuel and ignition maps are stored in a file which is flashed on a ROM chip that the ECU reads from right? i need that file.
Old 08-24-2003, 01:00 PM
AF - Advisor
Its not quite that simple. But either way, I dont have that info.
Kevin Jewer
Old 08-27-2003, 01:09 AM
well thanks anyway. say, could you post up the numbers in the maps? that would help too.
Old 08-27-2003, 01:57 AM
AF - Advisor
Long story short (I dont have the maps here at work) the ECU will go onto the highest airflow maps at over 2.1 grams per rev of airflow. For example, I get up to about 3 g/rev at my level. It will go for timing of 16-17 degrees advanced after ~6k rpm, and it shoots for a 9.5-10:1 AF ratio. At lower airflow however there are dozens of other maps that gradually lean out AFR and increase timing as airflow per rev goes down.
Kevin Jewer
