Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 08-12-2003, 03:31 AM
crj_lll crj_lll is offline
Send a message via AIM to crj_lll Send a message via MSN to crj_lll
Custom Ecu
Ok, here is the deal. I have a 1992 Honda Prelude with a P13 and an H22A4 engine. The car runs fine, but the AC Compressor does not work as it should. I have trouble shot and determined that the problem is an internal ECU problem even though the pins line up.
What I am asking a technician to do is take a P14, my original ECU, and use that as a map to rewire the appropriate pins on my P13. The pin location on each ECU is the same, but the function is different somehow. I have a pin breakdown for both ECUs and I would also provide the P14 for you. Is this possible for the right technician?
Resetting ECU- 1995 Toyota Camry V6 XLE Techniker Camry/Camry Hybrid/Vista 1 07-07-2010 08:42 AM
avoid REV Limiter for 4AGE- BT ECU-6speed MT Petroahorro Sprinter 0 06-18-2010 09:22 AM
avoid REV Limiter for 4AGE- BT ECU-6speed MT Petroahorro Sprinter 0 06-18-2010 09:21 AM
Gear selector error and other ECU mysteries jarl Trans Sport 5 05-02-2010 06:33 AM
Flash ECU, will the car start without? schreib Rodeo | Passport | MU 1 03-15-2010 08:09 PM
