Old 08-11-2003, 11:28 PM
blade34609's Avatar
blade34609 blade34609 is offline
Car wont run past 3k RPM!
Hi,
I finally got my car to run and drove it.
Everything seemed fine until I put it in 1st gear and drove.
Once I went exactly past 3000 RPM and didnt shift b4 that the car will make very bad sounds and slow the engine down a little so u have to let off the gas or put it in Neutral.
But as long as u shift B4 3000 RPM each time it shift very smoothly.
Also, my check engine light is on and it never came on B4.
Thanks
1990 Honda Civic LX
5 Speed
1.5 Liter SOHC
K&N Cone Filter
APC Short Shifter
1988 Honda Civic STD Hatch
D16A6 Si swap
DX 5 Speed Tranny
90' CRX Si Gauge Cluster
Accel Performance Wires
Old 08-11-2003, 11:33 PM
BullShifter's Avatar
Check the ECU for codes. Lift passenger side carpet & turn ignition on then count flashes = code#
Old 08-11-2003, 11:35 PM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
Bad distributor.
Old 08-11-2003, 11:41 PM
blade34609's Avatar
ill check the ECU codes tommorow cause its pretty late now.
But u think it could be a bad distributor?
I just used it awhile ago and this problem never occured until now.
I did take a D16 dizzy cap and put it on the D15 one.
Is there a way to test if its a bad dizzy?
Thanks
1990 Honda Civic LX
5 Speed
1.5 Liter SOHC
K&N Cone Filter
APC Short Shifter
D16A6 Si swap
DX 5 Speed Tranny
Old 08-12-2003, 12:40 AM
mellowboy's Avatar
Thanks
In my old stock motor thats what happened to me. I changed the coil and it ran find but then it died a week later. Ended up getting a new distributor.
