Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 08-11-2003, 10:13 PM
n4ji n4ji is offline
Send a message via AIM to n4ji
Making switch for twin radiator fans?
Over the summer, my cutlass ('94, 3100) has been running quite hot... about 210-220. I've put my water in the coolant, but to no avail. I came up with the idea of rigging a power source to both of the radiator fans, and have a switch in the interior, so I could turn them on free at will. How would I go about doing this? Any suggestions?
I'm a firestarter, twisted firestarter!!!
Old 08-12-2003, 06:37 AM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
The cooling fans are controlled by the PCM and are turned on at a predetermined tempature.
The primary cooling fan turns on at 225 degrees and the secondary fan will turn on at 232 degrees. They should cycle....turn off when the temp cools off to about 215.
So if I'm reading your post right, your vehicle is operating within designed specifications.
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 08-12-2003, 10:31 AM
I'm talking about when I idle at stop lights and such. If I'm stopped for more than abotu 20 seconds, the temperature shoots up to about 23-240. I just dont' want my car ot overheat. Is there anyway I can test the fans' motors to make sure they work???
Old 01-04-2004, 11:26 AM
Retardo Retardo is offline
Re: Making switch for twin radiator fans?
One way to test is when the temperatures get that hot, get out of the car and look to see if the fans are working. Another way is you can use an insulated wire and stick it in the hot side on the fan and stick the other end on the hot side of the battery. IT should engage if it's working correctly.
