| Off-Topic Talk about anything other than cars. |
I am looking for any suggestions for good a Programable ECU brand for my 97 Eclipse RS. Because i am adding Turbo, NOS, JE Pistons, Injeckters, Cams, and i few others.
Any help would be awsome, thanks. |
Two choices, Stand-alone or piggy-back style computers
Chris Clark www.Talon007.com 1990 Eagle Talon TSi AWD - In Progress 1993 Eagle Talon TSi AWD - Parts Car 1990 Eagle Talon ESi - Sold 1-800-VFAQ - Bookmark it, read it, use it __________________ |
If I had the money, Ill go DSMlink
not sure if that works on an 420 though, anyone know? |
THE GREEDY E-MANAGE is kool and onlt about $650 and is a full piggy back computer.. you can do all the boost seetings, air\fuel you know all the good stuff..
1
![]() Shift_BOOST 97 s14 |
check out www.2gnt.com for any info about the non-turbo cars. You might want to be more specific with what you're looking for. It sounds like you're just naming famous parts that people use & do.
Rob
"Got car lenghts?" or "You can turbo anything but can't make stupid people smart, something wrong with this picture?" |
Nope $595 thats not that much, considering us Canadians are paying around $800 for it
Just a thought though, why would you want, both a turbo charger and a nitrous system, Forced Induction and NOS usualy don't co-operate all to well un less you REALLY know what your doing. Also they are for typicaly two different autsports.
Don't mean to contradict you or discourage you of something you are sure of, just curious. |
n.o.s. helps racers during turbo lag.. while the turbo is spoolin you can use the nos to help you off the line and give you some boost untill your turbo kicks!
1
mm hmm, that i know, also it's benifical for the turbo as the nitrogen cooling effect will leave behind cooler exhaust.
But the only people that regularly do this are those like pro drag racers, well that's at least what i know. From what i've heard from my work, i came to understand that NOS and FI engines usualy don't work because of something about the cams and then engines cylinders won't take kindly to it. it wasn't explained to me much beyond that, so if you could explain it to me, or direct me to someone or somewhere that will, i'd appreciate it, i jioned these forums to learn as much as i possibly can . ANyways Thanks ahead of time.
i'm not just naming off parts...
sense my car is a none-T i was told by a friend that owns a honda shop i need to get a programmable ECU not just a piggy-back. I am looking at gettin a Haltech, any one know if they are any good let my know. |
Oh woops, i withdraw my question, brianyoung does know what he's doing, i didn't notice the cams on his original post. as long as he gets the proper performance cams he should be just fine with both Turbo and NOS. Should of read it properly the first time i guess
Stand-alone is good, if you know what you are doing, it can blow up your engines 1000 times from sunday
Well , starting with a 420A is just not a good idea. BUT , if you really want a stand-alone plug and play ECU thats adjustable , try AEM's new unit. After spending all that money , however , you'll be just about even with a regular turbo Eclipse. If ya wanna do something real , at least start with the right engine.
'90 Galant GSX , AWD , 5spd. Waiting on an engine swap. '03 WRX wagon , AWD , 5spd. Waiting on a paycheck.
Re: Good Programable ECU
Rob
So far I have done the following:
JE pistons Port & Polishing New springs and titanium retainers Customized throttle body New Pulley’s AEM Cold air intake (will replace after turbo is installed) Apex N1 exhaust (purchased but not installed yet) About to do Custom cut cam Garrett turbo kit NOS |
