Go Back   Automotive Forums Car Chat > Racing > Street Racing
View Poll Results: What is the faster car?
1991 VW B3 Passat 2.0L 6 20.00%
1995+ Ford Mustang 4.6L 24 80.00%
Voters: 30. You may not vote on this poll
Old 08-11-2003, 11:56 AM
speedman2049 speedman2049 is offline
Where's all the power on a 4.6L Mustang?
I cant help but notice what the hell did Ford do with the
newer mustangs that use the 4.6L?
The car has got no power compared to the originall
v-8 5.0L mustangs and why is this? The newer mustangs have
a extra 5hp over the older 5.0L.
The reason i ask is because i have a 91 VW B3 Passat
and i raced against 3 or 4 newer 4.6L mustangs and burned them
without even using my NOS. On the other hand, against a real 5.0L
and i was smoked like no tommarow.
Go figure why!
L.L.
Old 08-11-2003, 12:37 PM
carguyinok's Avatar
carguyinok carguyinok is offline
Power
I Would have to say its not the stangs that lost the race but the drivers . I cant say I have owned a newer mustang with the 4.6 but I have put a few miles on a SVT Cobra stang I will say they are a trick for finding the so called sweet spot for power in the rpm range. They have a lil more power but the rpm range is much higher and needs to be used. I am sure if the people had the old 5.0 stangs first they are shifting far to soon for the 4.6.
I am not putting your ride down. I am just saying the stang loss would be all on the driver not and on the car.
Old 08-11-2003, 02:40 PM
Jm93's Avatar
Jm93 Jm93 is offline
Send a message via ICQ to Jm93 Send a message via AIM to Jm93 Send a message via MSN to Jm93 Send a message via Yahoo to Jm93
;-) it should be 96 + 4.6 mustangs by the way ;-). i belive they began in 96.
and as for the power, im not sure, but the 4.6 is a way way better engine. much more reliable, and whatnot. if you need more juice, go for a cobra ;-)
http://members.cardomain.com/jm9301
It runs once more. Parked for winter.
Old 08-11-2003, 04:07 PM
carrrnuttt's Avatar
carrrnuttt carrrnuttt is offline
Re: Where's all the power on a 4.6L Mustang?
Go figure why!
L.L.
All I want to know is...
...what mods have you done to be beating stock mid-15-second/high-14-second cars (assuming the SN95 'Stangs), with your mid/high 17-second car? I am assuming no turbo's are involved, since you only mention "D.O.H.C." under your avatar, not "t" or "tt" like most turbo-VW owners proudly advertise. That 2.0 motor of yours produced 110HP, I believe.
Not knocking ya, but I am however, trying to head-off the flames from 4.6 owners that cruise this site. Also, you apparently haven't run into any of the '99+ 4.6's.
2002_Nissan_Maxima_6-speed
Old 08-11-2003, 04:15 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
Re: Re: Where's all the power on a 4.6L Mustang?
Bingo!
You took the words right out of my mouth.
Old 08-11-2003, 06:33 PM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
Exactly my thoughts as well!!
As what was said about the newer 4.6's having 5 more HP then a 5.0L, that is just false! 99+ 4.6's are rated at 260 hp at 5250 rpm's. The first gen 4.6's 96-98, were not all that great, and lacked power. Actually the 96 and 97 had 10 less hp (215hp) then the 5.0's and the 98 had the same hp (225hp) as the 5.0's.
If you actually beat a 4.6, then it's purely cause the driver had no clue what he was doing, which I can definitely see happening. The 5.0's had an excellent low end compared to the 4.6's which prefer the higher rpm band.
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
Old 08-11-2003, 07:06 PM
94svt5.0's Avatar
94svt5.0 94svt5.0 is offline
The 4 or 5 mustangs you raced, could possibly have not known you where even racing. The 96-98 4.6 was an underpowered disapointment. Ford finally did in 99 what they should have done in 96 and improve the heads. Anyway, its supposed to be more efficient then the 5.0, gas mileage ect..
More photos and Info/website!
1994 Cobra
-off road h-pipe
-superchips power chips
-mac cold air induction
-BBK aluminum underdrive pullies
-pro-m 75mm bullet MAF
-18" konig wheels with nitto 555 zr tires
-Ford Racing 65mm throttlebody
-Ford Racing king cobra clutch
-Ford Racing 3:73 Gears
-Ford Racing Aluminum driveshaft
-Bullit suspension/ springs,shocks,struts
-Aubrun HD limited slip Diff.
2002 subaru Impreza RS
- stock
1989 Toyota pickup 4x4
-K&N
Old 08-11-2003, 08:36 PM
Mustangs
I also wanted to let you guys know that i personally love mustangs myself, so I have nothing against them.
What i am saying however is that it occured several times that
I did beat them, oh and if you'r wondering if the other drivers
did not even know if they were or were not racing me, you don't go 190 kmh+ on a 50 kmh zone so yes a race was on.
Under the hood: 2.0L D.O.H.C. (135 hp (stock) at the wheels), piper cams,light weight pulleys, ceramic manifold, medalion muffler and 3" piping, modified semi electronic/semi mechanical air float system w/ cold air intake and a custom NOS dry kit shotting out fan spray nozzle w/110 hp jets.
My engine is producing about 200 hp w/nos about 300 hp.
Keep in mind i am not putting down the Mustang, in contrary i love that car and i am planning to get one, this is why i am getting peoples opinions.
L.L.
Old 08-12-2003, 07:20 PM
-Josh-'s Avatar
-Josh- -Josh- is offline
Automotive love doctor
Send a message via AIM to -Josh-
Well i guess he told you guys huh...
Self improvement is masturbation
AF User Guidelines
What is a mippie? - click
Old 08-12-2003, 09:58 PM
SiXPuSHA SiXPuSHA is offline
Send a message via AIM to SiXPuSHA
Got DYNO?
Some Stupid mazda that's ALWAYS BROKEN!
Slow as hell and twice as ugly!
Old 08-13-2003, 12:40 AM
R1-rider's Avatar
R1-rider R1-rider is offline
Send a message via ICQ to R1-rider Send a message via AIM to R1-rider
Re: Mustangs
did you add up all the added horsepower claims on the product boxes to get those numbers? cough
the 4.6 is a decent enough engine that can produce some nice numbers (only under supercharging though), like the 03 GT at 390hp and the 03 marauder at 355hp.
......or if your a loser who drives a Civic with a type R sticker, racing stripes, blasting really bad rap music through your suburban area with your pretentious "I’m 21 but I’m still in high school girlfriend" while driving with your hand up on the top of the steering wheel exposing your underdeveloped pasty white vitamin deficient arm and wearing your backwards BS upside down visor hat while feeling the tacky as a "Florida vacation" single diamond earring in your ear, If you are this person...with any luck the sun in its precise celestial positioning as you putter on by...will reflect its scorching rays into your earring, bouncing intensely in your rearview, and finally making contact with your eyes through the thin cheap lense of $5 gas station Oakley rip off glasses.. then burning your retnal cones into smoldering melting gobs of ocular material as you are blinded by the purest form of energy in our known universe, and as you scream no one can help or hear you because they don’t know what’s going on since the weed whacker sound of your shitty tiny little muffler which makes the Civic sound like a 747 rages on underneath making everyone turn at disgust and comment to thier husbands or wives how much of a dickweed you are by attaching that automotive abnormality to your stock economical daily driver engineered by Japanese Automotive specialists to fit the needs for entry level business workers in their early 30's, however your pathetic looking $11,000 car which you want to look like a friggin spaceship with redundant ground effects is now out of control since you are blinded, and as your car plunges off the side of a cliff while you scream in the purest form of terror while knowing you have lived a horrid excuse for a life, by doing the bare minimum in every facet of existence, while getting fired from one pathetic job to another, the majority of your time spent slacking smoking dope, getting kicked out of school, polishing your "game" on sweet innocent underage girls you eventually 'de flower' through exhaustive yet succesful attempts to get the date rapist drugs you have stashed in the glove compartment, into your poor victims drinks while offering them to take the "Pepsi Challenge" while making your mother hate you, and your poor father who wishes he had a daughter instead of your pathetic ass, since a girl would be more of a man than you ever were, like the occasion when you were hit in the arm by a wild pitch in little league, then you cried like a fat kid who dropped his ice cream cone, I'm already envisioning you impacting the rocks below, in a spectacular fireball ignited from the residue hairspray from your girlfriend plastered in the fabric passenger seat, blinded by your earring, deafened by the loud "Bling Blingin", and I will smile and roll around on the ground in orgasmic delight while you are consumed by flames whose intense heat and fury will liquefy your bone marrow that I will use to make jelly beans out of and eat them happily at your funeral as midgets dressed like Alex 6005321 from "A Clockwork Orange" dance around your coffin to loud industrial style techno music and strobe lights, and I will sleep soundly at night knowing another successful conquest of Darwinism has been attained.
Old 08-13-2003, 01:16 AM
Neutrino's Avatar
Neutrino Neutrino is offline
Yaya Master
Send a message via AIM to Neutrino
all salute the flag
(\__/)
(='.'=) This is Bunny. Copy and paste bunny into your
(")_(") signature to help him gain world domination
Old 08-13-2003, 02:05 AM
fatninja19 fatninja19 is offline
Send a message via AIM to fatninja19
lol, look at the out come of the poll so far....
But anyways, the latest GT's(which have the 4.6) are definitly quicker than any stock 5.0 Mustang.. and that includes the lighter foxbody 5.HOOOO's
when in doubt, throttle.
Old 08-13-2003, 07:15 AM
I raced a stock gt without my headers on and it actually wasnt a bad race. Granted I shut it down after he put a few cl's on me, I dont think he was the best of drivers either
Old 08-13-2003, 08:51 AM
HiFlow5 0's Avatar
Stanger
Re: Mustangs
OK your car does not make a 135 hp stock at the wheels. It makes a 134 bhp. Your car stock also runs a 0-60 in 9.8 seconds, while the stock 99+ Mustangs run a 0-60 in 5.5 seconds manual tranny, and 6.3 seconds auto tranny. Car and Driver test drove a stock 99GT and was able to pull off a 14.2 in the 1/4 mile, and their drivers can't drive for shit. 5.0 Mustang&Superfords took a stock 02 GT and got a 13.72 at 101.8 mph. Add roughly a second to those 1/4 mile times for autos. So unless you sprayed the motor, which you say you didn't, I don't think your modified motor could pull it off.
Also how do you know your car is truly making 200 hp n/a, and 300 on the juice? I'd like to see dyno results? I believe you car stock is somewhere in the 17 second 1/4 mile range,(correct me if I'm wrong, but that's the info I got off the web.)
But hey what do I know about VW's? Just something sounds fishy here!
-2013 Ford Flex
-1999 Ford F150
