Old 08-11-2003, 11:06 AM
89MugenEF 89MugenEF is offline
Question Help me! The car stutters when cold?
What is wrong with my 89 hatchback? Sometimes when the engine is cold and I accellarate with the gas pedal pushed right in, the car starts to sputter. Then I drop it back in and the rpms go up it's fine,until I change it to a higher gear again. Has this happened to anyone else and does anyone know what this is?
Greg
[email protected]
Don't laugh, it's paid for!!!!
Old 08-12-2003, 09:36 PM
bigben21 bigben21 is offline
Send a message via AIM to bigben21
you got dual point or mpfi?
Old 08-13-2003, 12:14 AM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
maybe you just need to downshift?
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
Old 08-13-2003, 12:06 PM
4-Door Flunky 4-Door Flunky is offline
AF Premium User
It only does this when it's cold?
Usually when the motor won't rev up or stutters, it's because the distributor rotor is bad or the coil isn't cranking out enough juice.
If it does this all the time (not just when it's cold) I would suspect a clogged fuel filter.
Flunky
PS-Hmmm...I just read your post more carefully. It CAN rev up...it just won't do it in the higher gears.
That's totally weird. If it CAN rev up, then the rotor/fuel filter are fine...starts to sound more like a computer or sensor problem.
