Old 08-11-2003, 08:47 AM
doug294 doug294 is offline
Send a message via AIM to doug294
Question Gasket set & engine rebuild question
Where can I buy like a gasket set that has all the gaskets I need to do the rebuild on my D16? Also my car burns like a little oil, but I have a entire turbo kit. Should I put the turbo on and run like 5 psi or wait and rebuild my engine? I foud a guy that has new 8.5:1 JE pistons and eagle rods for $650, is that a good deal? Besides pistons, rods, and gaskets what else do I have to have to rebuild my engine?
Old 08-11-2003, 09:28 AM
91zc 91zc is offline
Try www.hondaautomotiveparts.com They should have evrything you need. And personally I would rebuild the engine first before you boost it since it sounds the engine is going out. I wouldn't run 8.5:1 pistons. That is really low and it will take alot more boost to make the same power if you keep the stock or a little lower compression ratio.
91 civic 4dr
b16a
14.8@94
