Old 08-10-2003, 09:28 PM
sandis90si sandis90si is offline
Send a message via Yahoo to sandis90si
sudden oil leak
recently drove 600 miles and only used 1/2 qt. On arriving back home after another 600 miles, oil light started flashing. It was 3 quarts low. Have noticed small oil trail into garage and small puddle, but only leaks for a few minutes after parking. Obviously only leaks when engine is running. Seems to be coming from near crankshaft cover, definitely above the oil pan gasket. Not coming from filter though. Any ideas?
Thanks!
Old 08-10-2003, 09:31 PM
BullShifter's Avatar
crankshaft cover? you mean oil pan?
clean the engine then inspect for leaks
my guess valve cover gasket and/or oil pan gasket
Old 08-10-2003, 09:38 PM
It's somewhere behind the timing belt covers, etc on the front of the engine. oil is hitting the bottom of the alternator belt.
Oil Pressure 130 Pounds Smith1000 Park Avenue 10 04-18-2011 08:39 PM
