Old 08-10-2003, 07:02 PM
Nitzhel Nitzhel is offline
Send a message via AIM to Nitzhel
Smile Idle problem
Quesiton: When my car is at a complete stop the idle drops and then dies. However, when the car is running fine and I take off the idle gets stuck at high RPM. !!!!!!
Nitz
Old 08-10-2003, 09:15 PM
YogsVR4's Avatar
YogsVR4 YogsVR4 is offline
Funding the welfare state
Send a message via AIM to YogsVR4
I am not sure what would cause the throttle to stick like that other then something being jamed up in there. Take a look around http://www.stealth316.com/ and see if there are some answers in there you can use. Good luck.
Resistance Is Futile (If < 1ohm)
Old 08-17-2003, 02:29 AM
m3mark m3mark is offline
Send a message via AIM to m3mark
Same thing happened to me not to long ago. Sounds to me you need a new speed idle control.
You can make any piece of sh*t fast but then all you have is a fast piece of sh*t.......
Old 08-20-2003, 09:06 PM
'92 Stealth RT '92 Stealth RT is offline
My car used to do this until I figured out that the waste gate in the fuel injector was tightened all the way down so I backed the screw off just a little bit and it hasn't died since.
Old 08-21-2003, 02:15 PM
nikepenguin nikepenguin is offline
thanks alot i just had this happen to me and the fix worked
