Old 08-10-2003, 06:38 PM
Jaymes's Avatar
Jaymes Jaymes is offline
Angry Stripping paint off body
Hi, how do I remove the paint off the body? The paint is a Tamiya TS-26 spray paint... should I leave it in a tub of nail polish remover or use the Easy Oven Remover suggested from another thread? Would these agents melt the plastic? -Thanks in advance
Old 08-10-2003, 06:49 PM
Mustangman25's Avatar
Mustangman25 Mustangman25 is offline
Send a message via AIM to Mustangman25
I don't know of many others that do this, but I use Pine Sol (household cleaner) to strip Tamiya paint. Put the Pine Sol in a plastic container, then put the model in and let it soak for a little bit. If you give it a few hours, then the Pine Sol should have soaked into the paint enough that you can simply rub the paint off with a brush or towel. HTH
Chuck
-Chuck
Old 08-10-2003, 06:54 PM
Jay! Jay! is offline
Horizontally Opposed
DO NOT use nail polish remover. It'll melt the plastic.
Common strippers also include Castrol Super Clean and brake fluid.
Check it out in the FAQ!
Hierarchy of Subaru:
(Click to see mine!)
Old 08-10-2003, 07:00 PM
freakray freakray is offline
AF Modelrater
Welcome to AF
Did you see this at the top of the Car Modelling forum:
Important:AF Car Modeling FAQ - * Look here first! * ver2.0
It's worth a visit, it would have saved you posting a question that is already answered in the FAQ
AF User Guidelines
Old 08-10-2003, 07:31 PM
Jaymes's Avatar
Thanks a lot for the replies, and yes I found the FAQ section RIGHT AFTER i posted once again thanks for the welcome
Old 08-10-2003, 07:58 PM
Jaymes's Avatar
Chuck
I just bought the Pine Sol... do I need to mix in some water or just plain Pine Sol? Thanks
Old 08-10-2003, 08:15 PM
Just straight Pine Sol-just a warning though-don't let it sit for too long (like more then a 2 days)-I've had problems with plastic becoming brittle if it soaks for too long, but you shouldn't have any problems so long as it is in there for about 7 (maybe less) hours. HTH
Chuck
-Chuck
Old 08-10-2003, 09:43 PM
Jaymes's Avatar
Cool, thanks! Time to go dip
