Old 08-10-2003, 03:35 PM
Strider Negro's Avatar
Strider Negro Strider Negro is offline
Send a message via ICQ to Strider Negro Send a message via MSN to Strider Negro
Nissan's CVTS
like the title says, what the hell is it and how does it differ from vtec or vvti.
i know it's a dumb question but i just wanted to keep informed.
Old 08-11-2003, 04:08 PM
454Casull 454Casull is offline
If you mean CVTs, they're transmissions.
Some things are impossible, people say. Yet after these things happen, the very same people say that it was inevitable.
Old 08-11-2003, 09:45 PM
rsxer45's Avatar
rsxer45 rsxer45 is offline
AF Premium User
I think he means CVTC (Continously Variable Valve Timing Control) which is similar to V-TEC. Read the sticky post at the top of the Engineering/Technical Forum for info on how V-TEC works.
"If you have built castles in the air, your work need not be lost. That is where they should be. Now put the foundation under them."
---Henry David Thoreau
"And shepherds we shall be, for thee my lord for thee. Power hath decended forth from thy hand so our feet may swiftly carry out thy command. And we shall flow a river forth to thee and teeming with souls shall it ever be. In nomine Patris, et Filii, et Spiritus Sancti."
---Murphy and Conner MacManus
Old 08-11-2003, 10:29 PM
Neutrino's Avatar
Neutrino Neutrino is offline
Yaya Master
Send a message via AIM to Neutrino
its not that similar to vtec.....
vtec changes both the lift of the valves and the timing
the CVTS just alters the timing
(\__/)
(='.'=) This is Bunny. Copy and paste bunny into your
(")_(") signature to help him gain world domination
Old 08-11-2003, 10:54 PM
rsxer45's Avatar
AF Premium User
yeah you are right. Sorry for the mistake. I always thought they operated in a similar fashion, but I guess it was ignorance on my part. Here some info I found:
"Q: Does the CVTC motor in the Spec-V work the same as the VTEC motors in Hondas? If they do, then is it possible to use a VTEC controller in a Spec-V?
Sarah: No, due to the continuously changing cam profile, CVTC cannot be controlled like VTEC. It is a continuous variable adjustment unlike VTEC which is either on or off. CVTC improves overall engine performance by supplying Constant Valve Timing Control through all operating conditions. The crankshaft position, camshaft position, engine speed, and engine coolant temperature input signals are sent to the ECU. The ECU sends a variable duty cycle to a pulse width modulated solenoid that works like an injector. By adjusting and directing the amount of oil pumped into the CVTC's chambers and allowed to drain back into the engine, the ECU controls the retard or advance of the cam up to 30 crank degrees (vs. 14 degrees on the older VTC motors). The cam is retarded at idle to create a smoother idle and decrease emissions, advanced in the mid range to increase breathing, and retarded at high rpm to increase peak horsepower and fuel efficiency. VTEC is like having a stock cam at low rpm and a race cam at high rpm. At high rpm, the VTEC solenoid opens to allow oil from the oil pump to flow to a piston in the rocker arm. This piston engages a lost motion rocker in an extra intake cam, locking it to the two rockers that control both intake valves. The intake valve on this second cam profile remains open longer which increases breathing. A VTEC controller interprets the MAP sensor signal, throttle position and rpm to activate the VTEC solenoid at the user's specified rpm. It can also add fuel by intercepting the MAP sensor signal and tricking the ECU into thinking the engine is flowing more air. The SR20VE has a more similar system to VTEC."
http://www.nissanperformancemag.com/...r02/ask_sarah/
