Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 08-10-2003, 08:14 AM
Civicsiassasin91's Avatar
Civicsiassasin91 Civicsiassasin91 is offline
Send a message via AIM to Civicsiassasin91 Send a message via Yahoo to Civicsiassasin91
Question Zc turbo Aplications
Im planning on Replacing my D16a6 with a ZC this winter and would like to turbo it as well. I've been reading different forums and most people are using the TD04H-15G turbo kit from greddy. Are their any other turbo apps that will work with the ZC just as well if not better?
thanks
I wilst judgeth thou, as long as thou posteth gayeth topics on the internet.
TLD's FINEST
Old 08-10-2003, 11:20 AM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
That is a good kit, but you aren't going to get a lot of boost out of it. The TD04 is very small. They use them on the twin turbo setups for Stealths and VR4s. They can only push about 9PSI to redline a piece. Also is that turbo ball bearing? If not I would look around for a different kit.
Old 08-11-2003, 04:51 PM
im not to sure i'll have to check about the ball bearing thing. Does it make a difference? I was only planning on running 5-7 psi.
TLD's FINEST
Old 08-11-2003, 06:01 PM
Polygon's Avatar
The Red Baron
In that case the TD04 will be plenty for you. Ball bearing turbos generally spool faster and last longer than sleeve bearing turbos.
Want to turbo a 96 Eclipse 2.0 non turbo donidavis Engine, Transmission and Drivetrain 7 12-02-2010 08:23 AM
94 turbo 94camarorider Engine and Transmission 0 05-28-2009 04:54 PM
86 celica turbo 4 sale celica 86 turbo Classifieds 0 04-16-2009 02:42 AM
Ford Probe 1992 2,2 turbo ptq Probe 0 04-13-2009 03:30 PM
89 probe gt turbo TURBO LEAKAGE sweetbiker Probe 0 03-08-2009 04:25 PM
