Go Back   Automotive Forums Car Chat > Nissan > Skyline | Skyline GT-R | Stagea | Laurel > Performance
Performance Discussion about performance modifications and issues.
Old 11-27-2001, 04:57 PM
newbie007 newbie007 is offline
Post how to launch start?
hey guys i`m a newbie. can anyone tell me how to launch start and whats the disadvan to the car if i do this. cheeeeeeeeers
:smoker:
Old 11-27-2001, 06:01 PM
WDRacing WDRacing is offline
I'm not sure what your asking. Do you want to know how to launch your car in a race?? Is it auto or manual?? What boost are you running?? What size and brand tires are you running??
WD
WDRacing
Its all in the name
Old 12-03-2001, 03:59 PM
drift's Avatar
drift drift is offline
Send a message via AIM to drift
with a manual, rev to 4000rpm and sidestep the clutch. if you're in a GT-R or GTS4, rev a little higher before dropping as the AWD system will cause the motor to bog due to a lot of traction.
realise that doing this type of launch may cause clutch chatter and possible driveline breakage if it's a common thing... the instant engagement and shock to the driveline can cause longterm damage to the tranny, clutch, drive shaft, differential, and drive axles.
if your car still bogs at a 4000rpm launch, try installing a boost controller if you're turbo'd to help control the wastegate, therefore allowing the motor to hold boost at low rpm. the original vacuum assist line on the wastegate will begin to open and bleed off boost as soon as you put a load on the motor. a boost controller will close this vacuum line, and only allow wastegate activation at the desired boost level, increasing low rpm boost/power.
Old 12-03-2001, 07:35 PM
kinggts25 kinggts25 is offline
Send a message via ICQ to kinggts25
Instructions on how to launch a 1982 1300cc Mitsi Mirage:
1. Ensure that you are in "Power" mode
2. Flat foot the accelerator untill you see smoke out the back.
3. Move gearstick in to 1st gear.
4. Drop the clutch and enjoy the .5 seconds of wheel spin.
5. Do not change into second, as you will bog down...
:finger:
what ? where? when?
Old 12-03-2001, 08:08 PM
moondog's Avatar
moondog moondog is offline
Send a message via ICQ to moondog Send a message via AIM to moondog
Talking
bwahahahahahahahahaha :evil:
The best thing about the new AF? I can post again
________________________________
Tsuki Inu, kujira-no norite
1996 R33 series 2 GTS25t coupe 173 rwkw
How to start the car properly? kohokoho Camry/Camry Hybrid/Vista 2 12-01-2003 09:21 AM
'00 Integra GS-R - how to start it off nubb Integra 4 09-29-2003 02:24 PM
how to start a shop newswap Girl Racers' Spot 15 08-20-2003 08:43 AM
How rumours start in the office!! Spec2 Girl COMPLETELY off-topic 17 11-20-2001 04:43 PM
