Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Engine
Engine intakes, exhaust, turbos, nitrous.
Old 11-27-2001, 03:29 PM
CanadianG's Avatar
CanadianG CanadianG is offline
Send a message via ICQ to CanadianG Send a message via Yahoo to CanadianG
Hi-Port - Low Port Question
Whats the difference between the two and how do you know what you have?
Women call my bedroom the COCKpit!
Old 11-27-2001, 03:33 PM
G-Forces's Avatar
G-Forces G-Forces is offline
Banned
Jeez I hope I get this right.
This is a low-port. Notice how the plenum (intake manifold) is situated?
Old 11-27-2001, 03:34 PM
G-Forces's Avatar
Banned
This is a hi-port...
Old 11-27-2001, 03:48 PM
CanadianG's Avatar
Do you know if there ..............
is a difference between the two other than visually?
Are they on different years? I have no clue since I thought all sr20de's were the same?
Old 11-27-2001, 05:43 PM
JustinP10's Avatar
JustinP10 JustinP10 is offline
Send a message via ICQ to JustinP10 Send a message via AIM to JustinP10 Send a message via Yahoo to JustinP10
On the G20, 91-93.5 was the high port, the later models are all low ports from the factory. There are slight differences in the motor, but nothing major, the biggest difference is the intake manifold. The power bands are slightly different, not enough for most people to tell though. You can only notice the differences once you have quite a few mods and/or you get the car onto the dyno. The characteristics of the two motors are very similar, pretty much identical, expect when you look at them VERY VERY closely, then you can start to see very little differences.
Justin McClanahan
95 G20
15.4 @ 91.4mph (2.4 60ft )
143.7whp and 131.4 ft.lbs
Primera (10:1) Intake Cam, HS CAI, HS Header, UR Pullies, 19* Timing, ACT, Lightened Stock Flywheel, GC/AGX, Pacesetter Short Shifter, and more stuff...
Old 11-27-2001, 08:41 PM
CanadianG's Avatar
thanx
"It finally makes sense to me
Old 11-29-2001, 02:22 AM
doodledo824 doodledo824 is offline
g forces , how come i have a coolant resevoir by the intake and you don't?
Old 11-29-2001, 06:22 AM
CanadianG's Avatar
So whats that next to the battery?
Old 11-29-2001, 07:29 AM
G-Forces's Avatar
Banned
Oh that's not my car above. At first I thought it was but I was wrong. I do have that stupid coolent resivoir next to my filter. That's one of the reasons the AEM intake didn't fit.
Old 11-29-2001, 05:46 PM
JustinP10's Avatar
That's not coolant, that's brake fluid. Your coolant overflow should be located on the right side of the radiator (driver's side)
OOPS! that's weird... i was looking at the wrong thing. can that be relocated on teh other side of the battery, like in the front?
Justin McClanahan
95 G20
where is my AC low Pressure port? uspres2020 Escort 5 10-08-2009 06:41 PM
high port vs. low port GVR-4&a90Si Engine 1 04-29-2004 12:21 AM
Possibilities of a high port / low port head swap? ky_infiniti2000 Engine 0 04-15-2002 05:34 PM
High port vs Low port.. G20er Engine 4 07-27-2001 11:07 PM
