Old 08-09-2003, 04:02 PM
rjs2121 rjs2121 is offline
Unhappy Brakes/Rotors & Starting Problem
I own a 2000 Grand Am GT. I have two questions for anyone.
I have been researching a front brake/rotor design problem with the Grand Am and have had no luck. I have had pulsating and grinding noises for about 12K miles. I have 58K on my car right now. Had brakes replaced, still happening.
Anybody have any ideas of what it may be?
Also, I have been having starting problems for about 8K miles. My Grand Am will start fine in the morning, but once it warms up everytime I try to start it throughout the day, it will crank but not turn over. If I give it gas it starts. Today I just replaced the fuel filter and that wasn't it. I am going to replace the fuel regulator.
Anybody have any ideas about this one too???
Please e-mail me ([email protected])with any suggestions....
Old 08-09-2003, 07:25 PM
Flatrater's Avatar
Flatrater Flatrater is offline
Main GM Guy
You are not alone with your brake problems. GM built the grand Am under tight brake tolerances, any change will cause a pulsation. GM has a fix on this that requires you to go to the dealer. What needs to be done is the rotor run out measured and a shim installed. Everytime you rotate tires or remove one the tires need to be torques tp spec in a star pattern, anything but this will cause the pulsation to come back.
The grinding noise is a combination or rust build up the brake pads. GM rotors rust real easy. I would sugest aftermarket rotors.
As for your hot restart problem it is a good idea to replace the fuel reg. But if the problem is still there take it the dealer.
Shop Foreman Buick Pontiac and GMC dealership
ASE Master Tech
ASE Advanced L1
GM Master tech
Licensed Aviation mechanic
96 Skylark starting problem mlb55 Skylark 0 03-14-2009 12:13 PM
98 Intrigue issues. ABS & Brake light & transmission problems stryker9603 Intrigue 1 01-19-2007 02:21 PM
2002 Highlander new brakes, rotors & tires ski_jessie_ski Highlander/Highlander Hybrid/Kluger 0 01-09-2006 09:34 AM
saturn disc brake rotors & tires fred077 General Discussion 6 08-15-2005 12:28 AM
Need Assistance Changing Brake Rotors & Drums xdelirious45x Blazer 1 04-11-2004 10:11 PM
