Old 08-09-2003, 02:57 PM
thecone137 thecone137 is offline
Send a message via AIM to thecone137
turbo leak?
i have a 95 integra LS manual. just got a t-25 turbo put on my car and now the car intermittedly smokes out the exhaust and downpipe/cat flange. it smokes intermittedly when i boost as well. what could be the problem? my engine is in great shape so i know its not that thx.
Old 08-09-2003, 10:19 PM
funkdaflex1 funkdaflex1 is offline
Well this could be many things 1) your piston rings are fried 2) your burning oil or 3) its just do to the break in period of the turbo 95% its this it will go away if it doesnt then its more than likely your rings my friends rings fried last night.........that really sucked
SOLD
V
D16y8-
-Greddy Turbocharger
-Greddy front mount intercooler
-Greddy type S BOV
-Greddy profec E-01 boost control
-Apexi N1 cat back exhaust
-Tokico Hp shocks
-Eiboch Sportline springs
-AEM cam gear
-MSD spark plug wires
-Walbro 255 fuel pump
-DC sports front upper strut bar
-B&M fuel pressure regulator
-B&M fuel psi gauge
-Tenzo R Pasion 5 17" white
-Hankooks ventus hr2 tires
-eclipse and mtx speakers
-Alpine CDA-7893
-Alpine XM radio module
Old 08-10-2003, 09:36 AM
how long does this so called "break in period" typically last for??
Old 08-10-2003, 06:30 PM
NiMiK NiMiK is offline
did you buy the turbo new or used? what color smoke is kicking out of the tail pipe? i've had that problem with a use turbo before. found out the seals on the turbo was bad and had to replace them. BTW, why are you going with a t25 turbo on you b18b?
Old 08-10-2003, 11:45 PM
Like 500 miles and if its black smoke your burning oil.
SOLD
V
D16y8-
-Greddy type S BOV
-Tokico Hp shocks
-AEM cam gear
-B&M fuel psi gauge
-Alpine CDA-7893
Old 08-11-2003, 07:24 AM
i went with a garrett T3 initially and was having problems with oil leaking, so then i went with this. I didnt really have enough money to go with another garrett and i lacked the knowledge to rebuild a turbo.
Old 08-11-2003, 07:28 AM
i cant tell exactly what the color is, but i to notice oil can be found when i wipe my finger around the inside the of the tail pipe. This could be from the previous turbo and all the oil it left behind in the down pipe burning off, but i've gone about 100 miles now and its still happening.
Old 08-11-2003, 10:44 AM
Ricochet's Avatar
Ricochet Ricochet is offline
Banned
Do a compression test to see if your rings are bad. Oil out the tailpipe is never a good thing...
1997 a4 turbo leaking oil 2qts 500 miles borninabarn '94 - '01 1 02-11-2014 10:41 PM
89 probe gt turbo TURBO LEAKAGE sweetbiker Probe 0 03-08-2009 04:25 PM
Turbo Leak? KrnAznEP 3000GT/Stealth 0 02-07-2008 10:46 PM
turbo leaks. ABigWeaney Eclipse Problem Diagnosis 1 02-05-2007 08:34 PM
turbo leak? 9192tsi Off-Topic 3 04-13-2004 02:11 PM
