Old 08-09-2003, 02:50 PM
blade34609's Avatar
blade34609 blade34609 is offline
Power Steering Fluid?
Hi,
When disconnecting the power steering pump and belt and completly draining the reservoir, and then installing it again do you have to bleed the system? Someone told me I had to, and I havent found where it says how to do it? Or do you just add new power steering fluid, like I was gonna do?
Thanks
1990 Honda Civic LX
5 Speed
1.5 Liter SOHC
K&N Cone Filter
APC Short Shifter
1988 Honda Civic STD Hatch
D16A6 Si swap
DX 5 Speed Tranny
90' CRX Si Gauge Cluster
Accel Performance Wires
Old 08-09-2003, 07:56 PM
BullShifter's Avatar
Use Honda Power Steering Fluid
After installing the new pump, fill p/s reservoir with fluid.
Start engine & turn steering lock to lock several times. This bleeds the system.
Check p/s res. & add fluid if needed
Replace cap
Power steering flush Windstar 98 - No place to work serge_saati Windstar 9 11-05-2015 08:02 PM
Problems with Acceleration and now Power Steering dbhynds '01-'05 Civic 5 01-06-2010 07:41 AM
Cutlass Supreme - which power steering fluid serge_saati Cutlass Series 1 12-07-2009 07:15 AM
92 Cutlass Supreme Power Steering Hose Mikey_G Cutlass Series 4 11-23-2009 01:47 PM
2000 PA Power Steering Fluid Check buickultra2000 Park Avenue 2 11-12-2009 10:12 AM
