Old 08-08-2003, 11:31 PM
PunsIntegraLs PunsIntegraLs is offline
Cool Teg Tranny Swap Part 2
i got the 98 integra ls automatic. I bid on a 98 gsr at a junk yard and its demolished except it has a manual tranny. Can this be done and what exact parts do i need to do all of this and how much would they cost.
Old 08-09-2003, 02:09 AM
94tegRS's Avatar
94tegRS 94tegRS is offline
if you got the gsr, the whole car you got everythign needed, you take out yours and the gsrs steering column, dash, heater box, and then swap that huge harness from the gsr into your car, the one that goes to the fuse block, ECU, 2 plugs from under hood harness on driver side, inot engine compartment on pass side, once you get going youll figure out the harness part, unbolt all the auto linkage in your car then you drop the auto out, remove the torque converter by taking out 10 i think 10mm bolts holding it to the flex plate, then tke out the 8 bolts holding flex plate, theyll say AT, get some that say MT cuz they are longer as the flywheel is thicker, unbolt the gsr's linkage, take the tranny out of the gsr and put in the gsr's flywheel and clutch onto your engine. then put the gsr manual up in your car, then install the linkage, switch ECU's and you should be good to go.
current
-84 datsun 720 4x4(2nd time)-93 accord-90 camry V6-90 warrior-94 300ex
history:
-01 R1-04 daytona 600-94 teg RS-95 teg LS
-91 teg RS-92 teg GSR-94 civic CX hatch (3 times)
-94 civic DX-96 civic HX-97 Accord LX-72 superbeetle
-74 beetle-84 silverado-66 c10-74 maverick-78 280z
-84 200sx-86 tercel wagon-95 mustang V6
