Old 08-08-2003, 08:20 PM
97civichx's Avatar
97civichx 97civichx is offline
Send a message via ICQ to 97civichx Send a message via AIM to 97civichx
cat-back exhaust question
so i've been looking around on AF and on ebay at catbacks and i havent been able to find a reason as to why there are different catback exhaust setups for different models of the same years. i get why the hatchback would be different but besides that i would think it would be the same right? or are there differences in the length of the piping or the bends?
97 civic hx
mod list: CAI, 17" wheels but now removed and much more to come.
not much of a list yet really
Old 08-08-2003, 10:39 PM
afroeman afroeman is offline
Send a message via AIM to afroeman Send a message via Yahoo to afroeman
Length and Bends have absolutely nothing different when it comes to having the same model. They should all apply the same. Width is the only thing and of course the wider the piping the louder the noise, better airflow, etc. But you shouldn't have a problem with bends and length when it comes to Exhaust. Good Luck with it. And if you need a Muffler I have an OBX racing muff that I will sell you for $115.
Old 08-09-2003, 12:21 AM
97civichx's Avatar
well i figured the piping would be the same but i wounder cause some of the models have the cat converter built into the exhaust manifold and some dont...so wouldnt the ones with it in the exhaust be shorter in order to fit it in? i dont really know much about it, thats only why i'm asking. i'm not sure if the setup i want will work. did any of that make sense?
97 civic hx
Old 08-09-2003, 10:26 PM
funkdaflex1 funkdaflex1 is offline
Another difference in exhausts is the materials used for the pipes and also the welds. But as for them not fitting whichever exhaust is stated for each vehicle and trim will fit.
SOLD
V
D16y8-
-Greddy Turbocharger
-Greddy front mount intercooler
-Greddy type S BOV
-Greddy profec E-01 boost control
-Apexi N1 cat back exhaust
-Tokico Hp shocks
-Eiboch Sportline springs
-AEM cam gear
-MSD spark plug wires
-Walbro 255 fuel pump
-DC sports front upper strut bar
-B&M fuel pressure regulator
-B&M fuel psi gauge
-Tenzo R Pasion 5 17" white
-Hankooks ventus hr2 tires
-eclipse and mtx speakers
-Alpine CDA-7893
-Alpine XM radio module
Old 08-09-2003, 11:33 PM
SilverY2KCivic's Avatar
SilverY2KCivic SilverY2KCivic is offline
Cali Guy
Send a message via ICQ to SilverY2KCivic Send a message via AIM to SilverY2KCivic Send a message via Yahoo to SilverY2KCivic
That's pretty much the reason. Also how the piping bolts up to the header makes a differance too. Si cat-back would be different than EX cat-back. Just as DX/LX cat back would have longer piping than EX cat-back due to catalytic converter location. This is all in terms of '96-'00 Civic I'm refering to here.
Silver '00 Civic EJ6 Coupe
PureHonda original member since Feb. 2000
D-series revolution For pics of my baby, click here!
All rights reserved... All BITERS served!
"The last time you had THIS much fun driving a car, it cost a quarter, and gyrated in front of the supermarket."
i have yet to see any well done imports around here. most are road toilets driven by some high school punk -Drift
hessemer69 on AIM
Old 08-10-2003, 01:58 AM
97civichx's Avatar
ok so assuming that an ex header would bolt up to all of the d16 blocks (such as my hx model) the same then couldnt you use an ex header with a high flow cat for the ex and an ex cat back exhaust and it would all bolt up as long as the header bolts to the head the same. so does the ex header work on other models for bolting up or is the bolt pattern different?
97 civic hx
Old 08-10-2003, 04:49 AM
Cali Guy
As far as I know, the EX header should bolt up to a DX, since they use the same block, just different heads. The intake manifold can be swapped between them as well, so you can swap an EX header to your LX motor, and it'll fit.
hessemer69 on AIM
Old 08-10-2003, 11:09 AM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
the header attaches to the head, not the block, so having different heads and same blocks means nothing.
the ex header will bolt right to the the dx, because internal parts are different, but the bolt pattern on the head is identitcal. if you attached the ex header, ex cat, and an exhuast for the ex, it will bolt up with no problems.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 08-10-2003, 03:24 PM
97civichx's Avatar
so do you think that setup will work for any of the d16 motors cause the bolt patterns are the same and it wouldnt throw a code to the ecu or would it?
i just want to be sure before i waste my money on the wrong parts that dont bolt up right or wont fit or cause problems with the ecu.
97 civic hx
Old 08-10-2003, 05:12 PM
crxlvr's Avatar
attaching an ex header to your dx motor will not trigger any codes to be thrown, as long as all the sensors are re-attached and working.
1991 Honda CRX
2003 Honda Accord
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 08-11-2003, 12:09 AM
Cali Guy
Incorrect, unless you add on an aftermarket cat converter, then your ECU WILL throw error codes. Remember than the DX cat is built INTO the stock header. You yank it out, and say goodbye to your cat unless you add an EX or aftermarket one to the end of the EX header.
hessemer69 on AIM
Old 08-11-2003, 01:39 AM
97civichx's Avatar
I actually have the HX motor but its the same thing pretty much with the cat on the exhaust manifold. i was planning on getting the ex header with an ex high flow cat and an ex catback exhaust. this will all work as far as i know right? as long as the ex header bolts up to the head correctly? so does anyone know if the bolt pattern is the same?
97 civic hx
Old 08-11-2003, 02:41 AM
Cali Guy
Yup, that setup will work. AFAIK, all D-series manifolds should interchange with eachother, except for the DOHC ZC D-series motor.
hessemer69 on AIM
Old 08-11-2003, 06:23 PM
whiteracer whiteracer is offline
Send a message via AIM to whiteracer Send a message via Yahoo to whiteracer
folks, there's proof that post count doesn't always necessarily mean more knowledge....(nothing against crxlvr)
SilverY2KCivic quote:
Name's David.
Old 08-12-2003, 02:43 PM
crxlvr's Avatar
it was written as to assume he be replacing the cat and re positioning his 2nd O2 sensor to get the readings from the after the cat.
1991 Honda CRX
2003 Honda Accord
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
