Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 08-08-2003, 06:12 PM
gtrguy gtrguy is offline
Unhappy loosing oil pressure
I have a 96 Dodge ram pickup. With 128K miles
Today on the way to work, i noticed my oil
pressure guage all over the place.
Staying at 40 for a few minutes, then dropping down
for just a few seconds. Then back up to 40.
I recently did an oil change, but dont see how i could have caused
this problem in doing so.
Any suggestions on what it may be?
Thanks for any help, Brad
Old 09-10-2003, 12:55 AM
89 iroc-z 89 iroc-z is offline
check the oil again see if your low. check the wire from the sending unit (could be loose)as well as the sending unit it's self (it is a ground sending unit so if you have a amp probe or a volt meter you can see if it jumps up and down)if you check that out and it's fine buy a new aftermarket guage and see what the oil pressure is you can get them for $20-$30. if it's still dropping it could be the oil pump pick-up screen is dirty. but to check this you have to drop the oil pan.
Oil Pressure 130 Pounds Smith1000 Park Avenue 10 04-18-2011 08:39 PM
