Old 08-08-2003, 04:28 PM
rbridges rbridges is offline
I need simple directions to find/remove ecu from 95 eclipse
I'm trying to help a friend out. Her ecu went bad and we bought another one to replace it. She has a 95 eclipse (non turbo 5 speed, if that matters).
I figure it's behind the center console. How hard is it to switch? How much time and what tools?
thanks
Old 08-08-2003, 07:27 PM
95_GSX's Avatar
95_GSX 95_GSX is offline
Send a message via Yahoo to 95_GSX
the ecu is located behind the center console. if you remove the drivers side panel of the console you will have access to all the ecu plugs. as far as completely removing the unit i am not sure how difficult it would be but i imagine it should take no more than 3-4 hours to do the swap.
Old 08-08-2003, 10:51 PM
thanks.
3-4 hrs!!! Do you have to remove a bunch of other stuff to get to it?
Old 08-09-2003, 03:44 PM
95_GSX's Avatar
like i said i have only needed to access my plugs, i am not sure what all else you might have to remove to be able to take the whole unit out, but if this much time is alloted to the project i am sure that it could be done, so they dont start the project thinking it would take an hour and be out of a ride to work cause they have their ecu half way out of the car, but if it needs replaced i guess they are out of a car any way. i think it could probably be done in two hours if a person is familiar with their car.
Old 08-09-2003, 04:04 PM
thanks again. We'll see what we got when I take the console apart.
Old 08-09-2003, 05:18 PM
Talon007's Avatar
Talon007 Talon007 is offline
Send a message via MSN to Talon007
Your service manual should have a detailed description on how to remove it.
It takes me about 20min to remove mine, but I've got 1G's
Chris Clark
www.Talon007.com
1990 Eagle Talon TSi AWD - In Progress
1993 Eagle Talon TSi AWD - Parts Car
1990 Eagle Talon ESi - Sold
1-800-VFAQ - Bookmark it, read it, use it
Old 08-10-2003, 04:32 PM
RockinWRX RockinWRX is offline
Send a message via AIM to RockinWRX
The 2G's is in the same position as the 1G's , just forward and a touch below the radio. The biggest thing is just getting the console out of the way , and possibly removing the radio , then unbolting the ECU from its brackets. 2G's are a bigger cluster **** than 1G's , at least the 1G's are pretty modular.
'90 Galant GSX , AWD , 5spd. Waiting on an engine swap.
'03 WRX wagon , AWD , 5spd. Waiting on a paycheck.
Old 08-10-2003, 09:21 PM
kjewer1 kjewer1 is offline
AF - Advisor
Non turbo ECU is in the engine bay, in front ofthe battery The turbo 2g ECU comes out in no more than 5 minutes. REmove both side panels (on sides of center console) and remove 3 10mm bolts. Unplug 4 connectors. 5 minutes. You'll have to go back inside and punch the clown for 3 hours and 55 minutes to make this a 4 hour job
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 08-10-2003, 11:33 PM
Originally posted by 95 GSXracer
Non turbo ECU is in the engine bay, in front of the battery
I actually knew that , beleive it or not , but I was not thinking in the NT car sense.
And what the heck is punching the clown................
Is that like spanking the monkey?
Old 08-11-2003, 12:52 AM
Talon007's Avatar
I think Kevin was reffering to the flat rate time to remove the ECU in a 2G is 4hrs, lol, what a crock
Chris Clark
www.Talon007.com
Old 08-11-2003, 12:55 AM
Its a nice deal if you are on the mechanics end of it...
Old 08-11-2003, 01:04 AM
Talon007's Avatar
Hey, thats me, sweet
Chris Clark
www.Talon007.com
Old 08-11-2003, 03:42 AM
AF - Advisor
Yes, punching the clown is the same as spankin the monk.
Kevin Jewer
Old 08-15-2003, 04:45 PM
95_GSX's Avatar
hey i can see the time estimation was a shitload off...lol. but like i said i havn't had to remove mine i just needed to splice into the plugs i wasn't sure how complicated it would be. so i looked like an ass, but at least the guy wouldn't have gottin into the project and ran out of time.
Old 08-19-2003, 03:38 PM
Re: I need simple directions to find/remove ecu from 95 eclipse
Thanks, found out the hard way; about took a friggin axe to the center console to find the invisible ecu
oh well, got it out now
thanks
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
