Go Back   Automotive Forums Car Chat > Automotive Art > Sketching and Drawing
Old 08-08-2003, 03:07 PM
supratwin supratwin is offline
Window tutorial
Hey all, I was wondering if someone could post a quick tutorial on how to shade windows. I've been having trouble and was wondering if anyone could show me how to do that cool reflection stuff. It would really help! Thanks alot.
Old 08-08-2003, 05:23 PM
simdel1's Avatar
simdel1 simdel1 is offline
ok, ill do a quicky for you, but it will be basic
Simon
Old 08-08-2003, 05:44 PM
simdel1's Avatar
sorry, its too late..what iv done looks absolutely shit. ill try later for you if someone else doesnt do it before me
edit:...ok so iv changed my mind...it doesnt actually look that bad. ill try to explain it as best as i can
Simon
Old 08-08-2003, 06:19 PM
simdel1's Avatar
ok, here it is...now bear in mind that this is not my usual quality of colouring, it was just a quick, rough scribble to explain what i am talking about.
picture1: i have done the basic outline of the glass section of the car in pencil, then sharpened the pencil up with a black pen. i have also begun to put in very basic shapes for the head rests on the seats. these can be very rough as they will be pretty much covered later
picture 2: a simple dash board and steering wheel has been added, again very roughly. Using a black marker (a white board marker in this case as my usual black marker has run out ) i have made a simple reflection in the side windows. a couple of random marks slightly above it makes the simple reflection seem more ''real'' and less perfect. I personally also like to add a couple of curved sweeps to the far left of the windscreen...almost like the refelctions of a couple of lamp posts or a building of some kind. this is just a personal thing that i think looks good but you may not.
picture 3: a bit of a leap this one but still relatively simple.
The rest of the glass area is filled with black pastel relatively lightly. areas beyond the dash are made quite dark. then using a rubber the side windows that can be seen through the windscreen are lightened. then as a final finish, highlights are added using white pastel. the join between the pastel and the reflection in the side window is given a smudged line of white, and a little white is used to highlight the dashboard, steering wheel, windscreen reflection and the B pillar.
i then added some simple red reflctions just to add something to my scribble.
i hope i have been some help. if i have not explained anything, then just ask and i will be pleased to answer anything you want to know. im sure there are many other methods that other people use so experiment untill you find the method that suits the rest of your drawings or the equipment that you have.
Simon
Old 08-08-2003, 07:53 PM
Good Charlotte Good Charlotte is offline
Old 08-08-2003, 08:01 PM
EMAXX's Avatar
EMAXX EMAXX is offline
Send a message via AIM to EMAXX Send a message via MSN to EMAXX
That looks really nice dude. I'm going to have to start using that once I can draw a little better.
Old 08-08-2003, 10:31 PM
Totally awesome, thanks so much. I really need that. Thanks again!
Anti-Theft Window Crank Device ? Intuit Escort 6 10-11-2011 02:00 PM
'95 Passat FL power window problem frescoraja '93 - '96 1 06-19-2010 01:44 PM
window regulator daspyderman LS | MKZ 6 03-09-2009 03:07 PM
93 regal 3 windows work 1 doesnt gmfan88 Regal 0 02-25-2009 01:00 PM
Window regulator troubleshoot anfrhm Sidekick 0 02-19-2009 12:40 AM
