Old 08-08-2003, 02:26 PM
rollinncoaster rollinncoaster is offline
Unhappy How good a mechanic are you? Please Help...
Hi, I am a computer science undergrad and I do not know anything about cars, but I do need your help. I was hoping somebody could share some knowledge with me. Here is my story:
We have three cars a VW 96 GTi, a WV Jetta GLS 97 and a Honda Civic DX 98, and all three of them have the Check Engine Light on.
The codes on the GTi are:
P1582 - Idle Adaptation at Limit
P0140 - O2 Sensor Circ.,Bank1-Sensor2 No Activity Detected
The car drives fine, no problems at at except the engine hesitates from time to time. When idle the gauge is not perfectly stable; it jumps +/- 100 rpm's. I have not done anything to this car, except than regular mantainance, replacing the Radiator Fan and the timing belt. Also, the A/C broke down last a couple of days ago; I week after replacing the timing belt.
The Jetta is throwing 3 codes:
P0303 - Cyl.3 Misfire Detected
P1583 - Transmission mount valves Short to B+
P0510 - Closed Throttle Pos.Switch Malfunction
The engine hesitates a lot. When driving, the cars loses power for half a second and then recovers. This is very annoying. This happens all the time, but more often when the engine is cold. The timing belt on this car was replaced a month ago and the A/C compressor broke down right after this was replaced.
The honda is only thowing a P0135- O2 Sensor Heater Circ.,Bank1-Sensor1 Malfunction. We just bought the car and I don't know what the previous owner did with this car.
If you have any insight, suggestion or comment, I would more than glad to hear. Please guys (and girls), I really need your help.
THanks.
RC
The only way to make your PC go faster is to throw it out a window.
-- Robert Paul
Old 08-08-2003, 06:13 PM
candlaudio candlaudio is offline
Send a message via Yahoo to candlaudio
well here goes, i dont know what is wrong with everything on all of them but one thing is for sure, you need to replace the o2 sensors on all the cars and then reset the computer by taking both the battery cables loose for about 5 minutes then see if the light is still on and check the codes again, now the 2 vw's will be on still cause you have more than one code but the civic light should go out. that is about all i know of right off hand but i am sure someone on here will be able to tell you what is wrong and how to fix the problem...
94 honda civic dx
d154b7
pacesetter header
btm stage 2 clutch
c.a.i
short throw shifter
altezza's
gauges and bezel
interior painted
dropzone coilovers with 2" drop
205/40/16 yokahama parada's
99 honda civic ex vtec
dc header
c.a.i
dual tip muffler
Old 08-08-2003, 06:29 PM
Thanks for the prompt reply . I will replace the O2 sensors. I think most of the error codes are because of this.
Thanks again.
RC
-- Robert Paul
Old 08-09-2003, 12:19 AM
BullShifter's Avatar
Question
Were the engine compartments detailed/cleaned on those car?
Old 08-09-2003, 02:13 PM
No, never. We bought the VW's from a local dealer and the volkswagen from a private owner and we never cleaned the engine compartments.
Now that I remember, when we bought the Jetta the check engine light lit up hours after we took it out the dealer. The next day we came back and they cleaned the T/B and clear the codes. Never had a problem again. (That was a little over two years).
Hope this helps. Thanks for the reply.
RC
-- Robert Paul
Old 08-09-2003, 07:45 PM
I was just wondering becasue silcone/solvent based dressings will ruin O2 sensor & a bunch of other shit. Water based is the only way to go for engine dressings.
Old 08-10-2003, 04:36 PM
NOw that I remember, the engine compartment on the GTi was cleaned a year ago. I think you are right becuase the CEL started to light up around that time.
RC
-- Robert Paul
Old 02-14-2004, 10:02 AM
O2 sensor replaced. Problem solved.
The O2 sensor was the source of all the problems. As soon as I replaced it, the car runs very smooth. It even improved the responsiveness of the engine.
-- Robert Paul
Lean Exhaust Code-Mechanic Can't Resolve-Please Help! JESSICAR Park Avenue 9 04-02-2009 03:35 PM
how good quality are "LEE" kits? Renelsisc Car Modeling 3 10-03-2007 01:07 AM
How good of mechanics are you guys? fearsomefairmont Non Specific 53 05-09-2005 04:55 PM
How good of a mechanic are you? rollinncoaster GTI 7 12-07-2004 07:05 PM
How limp wristed are you? Oz COMPLETELY off-topic 26 04-16-2003 11:16 AM
