Old 08-08-2003, 12:22 PM
dxhatchback dxhatchback is offline
new civic thread
ok.. since my other thread got turned into a bunch of guys calling BS on me, ill make a new one here
i want to go B16 turbo.. a low boost system for now... i have searched the board, and the net.
what i need is this
1. a website that tells everything needed for a B16A 1st gen swap into an EF car
2. Is there a company that sells a low boost turbo kit for the B16 in a EF civic? Do i have to mod a diferent kit to work with the EF?
3. Can i get an ET for a low boost civic with a really good driver?? Just a rough estimate... like 13 seconds? 14 seconds? I plan onusing a 75 HP wet nitrous kit
4. Any website that deal with turbo B16's or transplanting a B16 into a EF, post them here...
thanks alot
Travis
HONDA is the BOMB!
Old 08-08-2003, 12:33 PM
BLU CIVIC's Avatar
BLU CIVIC BLU CIVIC is offline
調整器
Send a message via MSN to BLU CIVIC Send a message via Yahoo to BLU CIVIC
Re: new civic thread
U DON'T HAVE AN EF
BUT....there is no such thing as a low boost turbo kit...only small turbo's and large turbo's with boost controllers
also if u want et on low boos we need to know how much psi ur talkin....i think stock b16's can handle about 8-10 psi...not sure...
are u sure u did a search b/c this subject is all too common
The name's Adrian
1990 Civic HB Si - 265.7whp/223tq @9.2psi. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 296.3whp/230tq @1bar. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 185.8whp/139tq. Tuned on NepTune by J.Mills
2006 G35 Coupe 6MT - Stock
2011 CR-Z - Stock
Old 08-08-2003, 12:35 PM
JDM 4g4D's Avatar
JDM 4g4D JDM 4g4D is offline
Send a message via AIM to JDM 4g4D
Get:
b16a1
89-91 teg axles
PR3 ECU
HASport Mount kit
HASport Linkage
T3/T4 Hybrid Turbo - Your choice what brand turbo, i rec. a Garret
Tial External wastegate 40mm 4 bolt
B-Series Trubo Manifold with 4 bolt flange
HKS super-sequential Blow-off valve
DSM Injectors
HKS Boost Controller
Some sort of Intercooler - dont go fast and furious and get a GodzillaCOOLER though, you'll get mad lag
All i can think of for now.
200whp ALLMOTOR CLUB
ALLMOTOR.NET
Car Photos
Old 08-08-2003, 12:40 PM
i know i dont have an EF... but im going to get one... i have 4500 USD to spend on the engine... i like JDM 4g4d's post... very informative.. i only want to run about 6 or 8 PSI to be safe, maybe less for everyday driving, but i want to be able to at least boost to 8 or 9 PSI...
i guess ill have to get charge pipes custom? can i use exhaust pipe? what size of exhaust should i run? 2.75? 3 inch?
thanks again
Travis
HONDA is the BOMB!
Old 08-08-2003, 12:42 PM
optimuscivic's Avatar
optimuscivic optimuscivic is offline
go here for a decent b16 swap guide
http://www.phatwhippincrx.20m.com/custom.html
As American As A Burrito!
USDM 4 life!
Old 08-08-2003, 12:43 PM
89-91 teg axles? isnt the generation from 86-89, 90-93 and 94-00?? or did the axles change in those years??
Travis
HONDA is the BOMB!
Old 08-08-2003, 12:44 PM
BLU CIVIC's Avatar
調整器
what u'll need for a turbo it
1. Garrett T3/T4 Turbo- The turbos trim is a/r 50, it has an external 7 psi wastegate on it, and does come with the mounting gasket.
2. Custom FMIC- It is designed for most honda and acura applications, its tig welded, 2.5” inlet and outlet, it measures 30x6x3 tip to tip, and the core is 2 ¾” thick, which flows 33% more air than a 2” thick standard core.
3. Turbo Oil Feed Line- this is a complete kit to run from your block to your turbo, it will work for any b16 and b16 engines.
4. Custom Turbo Manifold- this manifold is tig welded with laser cut flanges, it will fit any b- series blocks.
5. NO WELD Turbo Oil Return Kit- this is a no weld oil return line, its great for aluminum pans, like honda and acura ones.
6. Greddy E-Manage- includes the greddy e-manage, support tools and software, ingintion harness, injector harness,sensor harness, and turbo pressure harness.
7. ALUMINUM Blow Off Valve- exact replica of apexi, with great reliability.
8. Greddy Full Auto Turbo Timer- The GReddy Full Auto Timer packs tons of features in one economical, compact unit. In addition to two standard programmable count down presets, this timer also has two Auto Timer modes, which estimate the driving RPM according to the vehicle's alternator signal and then recommends a count down time. Additional functions include a Stopwatch/Lap Time mode, and Attack mode. There is also a built in Voltmeter and Speedometer.
9. Manual Boost Controller- One of the best boost controllers on the market…
10. Synapse Missing Link Valve- you need this in order to bypass your MAP sensor.
11. Walbro 255 lph fuel pump- it is great quality and relibilty..
The name's Adrian
2011 CR-Z - Stock
Old 08-08-2003, 12:48 PM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
there are b series swap link in the engine section at www.4thGenerationCivic.com
as for turbo...go to http://www.thedropshop.com/ he is a fellow civic owner who owns/runs a performance shop that pretty much specializes in turbo (in plain english....he is addicted to turbo). he can answer all your questions
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
Old 08-08-2003, 12:49 PM
where do i get these parts? most have a great discription, but no brand name or website!
Travis
HONDA is the BOMB!
Old 08-08-2003, 12:50 PM
BLU CIVIC's Avatar
調整器
more infor about the turbo's
http://homemadeturbo.com/tech_projec...ech/index.html
The name's Adrian
2011 CR-Z - Stock
Old 08-08-2003, 12:51 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
well if you gonna get a dx then u gotta do the mpfi swap. get a 90-93 teg halfshaft with 90-93 teg axles
and i dont think runnin a stock b16 @ 7psi with a 75 shot wet nitrous is advisable. but if u do run that set up i would say 12s but dont expect your engine to last long
Team Lonely Drivers
Old 08-08-2003, 12:53 PM
BLU CIVIC's Avatar
調整器
Travis
search for them....gave u what u need but u have to do some work....best thing is to search ebay b/c they will have a lot of each item with itz description...do ur research then come back
The name's Adrian
2011 CR-Z - Stock
VelocityCivic91's Avatar
VelocityCivic91 VelocityCivic91 is offline
Send a message via AIM to VelocityCivic91
You need 90-93 Integra LS axels, but you are going turbo, so I would go with reenforced axles... probly like stage 2 or 3.
WARNING: Surgeon General says it's O.K. to smoke V-8's.
*** Looking for a B&M fuel pressure regulator and guadge***
Old 08-08-2003, 12:56 PM
GTA's Avatar
GTA GTA is offline
Whee..
Travis
Your going to get an ED. Unless you plan on importing a jdm civic cause those are the only ones with EF in there vin tag.
AF Bay Area Crew
RIP Melt
2008 Mitsubishi Lancer Evolution GSR
2007 Toyota Prius
I <3 and miss my 4g
EFStali's Avatar
EFStali EFStali is offline
Send a message via AIM to EFStali Send a message via Yahoo to EFStali
ha ha ha..how much boost can a D15 engine handle? like 2psi? that would be funny as hell.
Name is Adam
New Mazda3Speed, New Civic Si, New VW GTI, Chevy Cobalt SS,Dodge Neon SRT-4, New Mini DriftinDraggin Car Comparisons 30 10-05-2007 09:24 AM
new civic progress pics thread. irupp33 WIP - Street 12 05-09-2003 07:40 PM
Open now new Gallardo thread DNovo Gallardo 32 01-06-2003 08:07 PM
New Crucifixion Thread moldyhands Lancer 128 01-10-2002 09:29 PM
