Old 11-27-2001, 04:30 AM
awaken1973 awaken1973 is offline
Send a message via ICQ to awaken1973
Best way to do window frames?
That's what i'm doing right now - painting black inside the window glass
I use masking tape for contouring, then brush it
but anyway paint leaks under tape a little bit and I have to wipe it after this
of course glass doesn't look perfect after wipe
Old 11-27-2001, 10:10 AM
DVSNCYNIKL's Avatar
DVSNCYNIKL DVSNCYNIKL is offline
R.I.P. DAD 3/25/11
Send a message via ICQ to DVSNCYNIKL Send a message via AIM to DVSNCYNIKL Send a message via Yahoo to DVSNCYNIKL
I would suggest that instead of using masking tape, use the frosty type scotch tape. It adhere's better to the plastic and you won't have that problem of it running under the tape. I only suggest you use this tape on the glass parts and not the body as it leaves some residue. So just use this technique on the window masking part.
Why do banks charge you a "non-sufficient funds fee" on money they already know you don't have?
Old 11-27-2001, 11:22 AM
Jay! Jay! is offline
Horizontally Opposed
I try a lot of things... none of them work perfectly.
The best so far is when you have masking templates for it. Tamiya provides them for race cars and some of the newer road cars. Fujimi sorta did in my MR2 kit: they put the templates on the back of the instructions, and I had to photocopy them, and apply them with 2-sided tape. Still better than nothing.
Otherwise, you're screwed. It's really hard using masks with brushes. They just plain leak. Airbrushing/spraying is the way to go there. If you can't spray, You can try it free-hand, but it's rediculously hard. Keep something handy to wipe off your mistakes.
Sometimes, when I'm super lazy, I just use a Sharpie permanent marker. If you do this, it's important to use as few strokes as possible, because the pen tip tends to smear the ink around on subsequent passes. At the very least, I always use a marker/pen to touch up something on the model, so why not just use it outright?
Hierarchy of Subaru:
(Click to see mine!)
Old 11-27-2001, 11:53 AM
Guiddy's Avatar
Guiddy Guiddy is offline
You can't brush paint windows!
Get some Tamiya masking tape, and spray a REALLY light coat for your first, covering only 50%. That seals the tape ready for another slightly heavier coat.
Perfect everytime!
Old 11-27-2001, 12:02 PM
ales's Avatar
ales ales is offline
Forza Schumacher
I tried Dan's method on my 1/43 Pug 206 kit and it worked perfectly!
Old 11-27-2001, 02:02 PM
primera man's Avatar
"P-Man"
If you use the Tamiya tape and spray them you will not get any leaks underneath the tape......trust me !!!
View All My Models Here.
Whats the best way to paint a Truck frame? DAVID2347 Engineering/ Technical 10 04-14-2008 03:23 PM
