Old 08-08-2003, 03:00 AM
hon808os hon808os is offline
sas carbon decal
i seem to be having a problem with the decal sticking to my model, after it dries it comes off easily....what am i doing wrong?
thanks
Old 08-08-2003, 03:13 AM
Focus2000's Avatar
Focus2000 Focus2000 is offline
Evil Genius
Are you soaking it in water for too long, so all the glue is dissolving? All you need to do is dunk it in the water and leave for a 10-15 seconds.
A little off-topic, but slightly related - I got my SAS CF decals the other day and think they are brilliant! I thought I'd mess about with my Enzo headlight unit and try to CF it. It's a difficult shape, but with some persuasion with a bit of MicroSol the decals went on very well. They conformed to the angles and curves a lot better than I expected, and have a very good pattern. I will certainly be getting more in the future
Now if only Chris would do Kevlar as well
Chris
Old 08-08-2003, 04:23 AM
flyonthewall's Avatar
Car Mod guy
What did you do to it to make it come off?
Old 08-08-2003, 08:16 AM
Vric's Avatar
Vric Vric is offline
I got the same problem too the first time i used it.. scrap half of the sheet, but i'm really sure it's becose I waited too long in watter
Old 08-08-2003, 09:03 AM
Dr.AK's Avatar
Dr.AK Dr.AK is offline
euh... i got a question about these decals, if you put them on a hood er something, do you cut them to shape before you put them in the water or just do you cut them roughly in shape and cut off the overstanding pieces after it was applies and has dryed??
i'm thinking of ordering some of them in the future but before that i want to know that.
Old 08-08-2003, 09:25 AM
thizishkenny thizishkenny is offline
Send a message via AIM to thizishkenny
yes that happened to me too. It just wouldnt stay on the car but im pretty sure its because i didnt use microsol at that time but now i bought some so now i will try again with the cf decals.
Old 08-08-2003, 09:28 AM
Vric's Avatar
yea i didn't had microsol at this time... maybe it's the problem
for the cutting question, you need to cut it before.. you can make it about 1cm larger on every direction and you flip it under the hood.. if you want, you can cut it when dry.
Old 08-08-2003, 09:45 AM
Car Mod guy
These decals really don't need long in water, 10secs and that's it. Never leave decals soaking anyway, place them in water for a few seconds then place on some tissue to soak up the excess water and leave for a few more seconds while the glue dissolves.
Too much of a soaking could have caused the problem you mention, so too can a poorly prepared surface or an incorrectly finished one. Never apply to a matt surface as it won't stick.
Microsol also helps to adhere decals better cox it will bond it with the paint.
Old 08-08-2003, 11:06 AM
Hey Chris, would it stick to primer because thats what i did?
Old 08-08-2003, 11:33 AM
Car Mod guy
Primer is a matt finish so you wont get good results. If your doing a hood then paint it gloss or semi gloss black first.
Old 08-08-2003, 01:37 PM
thanks everyone i'll try your suggestions i hope i can get it to work better thanks
Old 08-08-2003, 09:39 PM
can i use duplicolor clear coat over the top of the decal.....if not then how about future floor polish?
thanks
Old 08-09-2003, 04:30 AM
Car Mod guy
thanks
As long as you build up several very fine mist coats first so that the paint won't attack the decal, it will be fine.
Future wont be such a problem and can be applied straight on.
