Removing the dash...
Are there any detailed instructions on how to do this?
UNOFFICAL AUDIO BRAND RATINGS My life is composed of the worst luck known to man. Disclaimer: My knowledge of car audio is questionable, but it usually sounds great to me. '98 Grand Prix GT 4Dr '06 XXX 12" Possibly a Cadence ZRS-10 Pioneer DEH-5500MP
Can anyone help me?
You asked for it!
Disconnect the battery ground negative cable.
Disable the SIR system. Remove the instrument panel (IP) insulators. Remove the LH and RH carpet retainers. Remove the windshield side upper garnish moldings. Remove the IP upper trim panel. Remove the front floor console, if equipped. Remove the steering column opening filler. Remove the knee bolster. Remove the steering column. Remove the IP cluster trim plate. Remove the radio. Remove the HVAC control assembly. Remove the IP cluster. Remove the headlamp switch. Remove the instrument cluster HUD dimmer switch, if equipped. Remove the instrument cluster HUD display, if equipped. Remove the driver information center. Remove the IP compartment. Remove the IP compartment lamp switch. Remove the inside air temperature sensor, if equipped. Remove the IP trim pad bolts at the windshield. Remove the left side lower trim pad mounting bolts Remove the IP cluster pocket mounting bolt Position the IP wiring harness aside. Remove the IP trim pad from the vehicle. Install the upper IP trim pad bolts. Tighten Tighten the bolts to 5 N·m (44 lb in). Install the IP cluster pocket bolt (1). Tighten Tighten the bolts to 5 N·m (44 lb in). Install the left side lower IP bolts (1). Tighten Tighten the bolts to 2 N·m (18 lb in).
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again? Got all the certifications 25 years ASE Certified Master Technician GM WCT Yea..I work at a DEALERSHIP....got a problem with that? Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality) This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video PM Me for details |
Let me respecify. How do you remove the big ass plastic thing blocking access to the radio?
Lower the steering wheel and pull it off. I had to do it three times today. I wouldn't mess with the lower one though, I about broke mine.
Kevin Lee |
