Old 08-07-2003, 05:43 PM
DJ_EpHaNt DJ_EpHaNt is offline
Problems w/ VTEC after SWAP
I recently swapped my 95 Accord LX engine with a 97 Accord EX engine. The ECU got switched out with the engine. The mechanic that did the swap is not a Honda specialist, so did not have much knowledge of the wiring of the VTEC engine.
I got the car back, it runs fine and seems to have more bottom end than it did before. But now when I get up to 4500 RPM (when the VTEC should kick in) I loss significant power, and my car has no power past 5000 RPM.
I believe this is a case in which the VTEC just isn't wired into my car correctly, and just is not kicking in. But shouldn't the car be able to run past 5000 RPM without the VTEC? Or is all power past the 5000 controlled by the VTEC?
Thanx...
AC
Old 08-07-2003, 07:46 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
VTEC is controlled by your oil level, and the car should run past that 5000rpm mark, check your oil level first, then start diagnosing other symptoms with the wiring.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
