Old 08-07-2003, 03:47 PM
perna00's Avatar
perna00 perna00 is offline
Send a message via AIM to perna00
Unhappy expert techs only
someone please help. i have a 96 with a 2.4. i have a cold air intake, headers, free flow cat, cat back exhaust, and an underdrive pulley. i'm getting alot of fluctuations in the readings of the map sensor and the camshaft positioning sensors. it's not running like it should performance wise. when i first start up the car and it's cold, i can smell gas strongly in the exhaust and it hesitates for the first mile. hopefully someone can help me cause all garages i take it to are clueless. thanks
Old 08-07-2003, 10:15 PM
spdracr87 spdracr87 is offline
Send a message via AIM to spdracr87
well the strong smell could because of your highflow cat...i have no cat on mine and get a pretty strong smell. so im sure the high flow cat lets some bad air through that has not such a pretty smell.
1987 honda crx si.
under hood mods.
1. custom built cool air intake
2. 4/1 header.
Exhaust
1. high flow cat.
2. and pace setter cat back tooned exhaust.
sytem soon to come cab is being custom painted maybe. and out side is being painted soon.
FOR SALE!!!!!!!!!!!!!!!!!!!!!!
Old 08-09-2003, 03:42 PM
perna00's Avatar
i think that maybe my wiring harness going to my pcm could be loose or need replaced. would that make the reading fluctuate or would that only make them fail if the connection was loose? i also have an air/fuel controller that digitally displays the tps reading, it also flashes between 2 readings? does the tps, cam p s, and the map sensor wires come from the same wiring clip on the pcm? there's 3 sets. i'd really appriciate any advice someone could give me. thanks
Old 08-09-2003, 07:35 PM
Flatrater's Avatar
Flatrater Flatrater is offline
Main GM Guy
They do share a common groundwire!!!
Shop Foreman Buick Pontiac and GMC dealership
ASE Master Tech
ASE Advanced L1
GM Master tech
Licensed Aviation mechanic
Old 08-10-2003, 01:45 AM
perna00's Avatar
do you mean the groundwire from the engine to the chasis, from the pcm to the chasis, or the wire comming off the sensors themselves? and if you could, the location it's at. i'd really appriciate it, thanks.
Old 08-10-2003, 07:04 AM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
The PCM grounds are usually found on the transaxle to engine block mounting bolt...there should be one bolt with a stud on it with a gang of wires (usually black with a white tracer)
remove the wires, thighten the bolt, clean the mounting stud and wire rings and reattach.
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 08-10-2003, 08:37 AM
perna00's Avatar
thanks, i also see that there is no engine grounding strap on top the ignition housing, that's where i noticed the strap on a 2.3. is there supposed to be one on top of my 2.4?
gm/pontiac tech/expert help with BCM Brettgilroy05 Cavalier Problem Diagnosis 0 05-05-2010 10:27 PM
For Mazda techs. only MeettheCreeper General Discussion 0 10-19-2006 01:18 PM
all the ?'s i can think of in one topic. (gagt experts/owners only please) TrAnCeD_RaCeR Grand AM 2 10-01-2002 05:01 PM
