Old 08-07-2003, 02:56 PM
CamaroSSBoy346's Avatar
CamaroSSBoy346 CamaroSSBoy346 is offline
Send a message via AIM to CamaroSSBoy346
Unhappy Help!!
Say hello to my newest project: Project "nice rice," i do have a couple of custom pieces for it, but more pics later, but right now im having a problem. With the Fujimi Honda Civic EK4 it has an option to make a sun roof, so they engrave a rectangle in the roof to cut out for the window but i dont want the sun roof, and they engraved it to deeply, and its caving in. Does anyone have any suggestions, or do i have to resort to putty?
2002 F150 SuperCab FX4 6" Fabtech, 3" BL, Detroit locker, Edge tuned, Yukon 4.56s, 37" Nittos, Harley lights, Depo fogs, 8K HIDs, Powerstop brakes
1992 Lincoln Mark VII LSC 302 H.O, A9L ECU swap, 65mm TB, 73mm Granetelli MAF, FRPP 30lb injectors, Walbro 255, MSD ignition, Powerdyne BD11 supercharger, Efans, T-5 swap w/ FRPP flywheel, Ram HDX clutch and adjustable Steeda clutch quadrant, 4.10 gears, Nitto NT555R radials
2000 OBS Tahoe Z71 6k HIDs, 33" Goodyears. 280k mile daily beater
Old 08-07-2003, 03:04 PM
freakmech's Avatar
freakmech freakmech is offline
Send a message via AIM to freakmech
I dont see any caving in? could you be more specific? you will have to putty the engraved lines if they are deep and cant be sanded. you can glue styrene sheet to the under side for added strength. if explained with more detail i could be more helpful. oh, and what are you doing building an import
Old 08-07-2003, 03:23 PM
hobbes874's Avatar
hobbes874 hobbes874 is offline
Send a message via AIM to hobbes874
doesn't look like it's "caving in". if you want to remove the lines putty will work.
All Newbies please read the F.A.Q's
"We are defined by the choices we make." -Fight Club
Old 08-07-2003, 04:08 PM
when i mean caving in, i mean the lines are caving in (about 3-5 mm wide now) for some reason the got bigger, wtf Anyways, i found my other Fujimi Honda Civic, and i'll use that body now
Old 08-07-2003, 08:33 PM
reveller reveller is offline
You are just imagining things from inhaling all those fumes while modelling.
reveller
