Go Back   Automotive Forums Car Chat > Nissan > Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail
Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail Nissans greatest 4WDs and SUVs
Old 08-07-2003, 04:30 AM
SYSTUM-X SYSTUM-X is offline
It rides like a tank
I just installed the Calmini 3" susp lift. I had to crank torsion bars to get the front even with the rear. But now my front end rides like a tank. It's stiff and bounces all over. I'm guessing I'm going to have to loosen the torsion bars. How should I adjust them so I can get the most lift and a softer ride? Did I install something wrong? What should I do?
Old 08-07-2003, 08:54 AM
OffroadX OffroadX is offline
Send a message via AIM to OffroadX
If you cranked the torsion bars to the point that the upper control arms are sitting on their bump (droop) stops at rest, then yes, you will get a crappy ride. Let 'em down a bit, give yourself at least 1/2" space between 'em and see if that makes a difference. It will still ride a tad nose-down as it did before you lifted, it's not supposed to be "level" anyway.
Of course, you'll need an alignment anytime you fiddle with the torsion bar settings.
Brent
Old 08-07-2003, 01:54 PM
XSAL XSAL is offline
If you literally just installed the susp. lift, it will take some time for the new torsion bars to "break in."
As Brent stated, you might have set the front too high, but once you set the front heigh correctly and give the bars some time to settle, the ride wouldn't be that bad...
Old 08-07-2003, 02:31 PM
Schludwiller's Avatar
Schludwiller Schludwiller is offline
XTerra Guy
You should be able to stick your index finger between the upper control arm and your bumpstop. Like OffroadX said if your truck is level you probably have the torsion bars too tight.
BTW which shocks do you have?
Xterra4x4.com and the Xterra Offroad Webring
Old 08-09-2003, 12:40 AM
ChuckH's Avatar
ChuckH ChuckH is offline
Put 5/8" between the upper bumpstop and the control arm. The torsion bars will settle for awhile so you will have to keep turning them up a bit. ALso, the rear springs will settle and the back will come down. The truck is designed to ride a little bit higher in the back. By cranking up the torsion bars all the way tot he bumpstop you will make an alignment impossible, make for a very bad ride (as you indicate), and you will have excessive driveshaft angles all the time.
As others mentioned, the torsion bars will also soften up a bit once they've been driven on. I run my front between 3/4" and 5/8" fromt he upper bumpstop and the ride is great!
ChuckH
looks like h**l, rides like a dream moomama Ninety Eight 0 01-27-2007 06:30 PM
ride like a caddy nswhite Wheels/Tires/Suspension 22 12-30-2005 02:32 PM
92 Sub rides like a haywagon, help! kkant Suburban 3 05-27-2005 01:11 PM
1996 Buick rides like a truck dave2318 Regal 4 03-15-2005 03:59 AM
FC rides like hell, what's the solution? kevinorhoades RX-7 1 08-16-2004 01:24 AM
