Old 08-06-2003, 10:29 PM
caminsc5 caminsc5 is offline
Send a message via AIM to caminsc5 Send a message via Yahoo to caminsc5
Exclamation car wont start
iwent to go to work tonite,i got in my car and went to crank it, it acted like it wanted to crank but didnt, so i turned the key off and went to crank it again......and nothing. it makes a loud click but it didnt turn over or anything. my lights and radio still came on, but it wont do anything does anyone know what is wrong? its a stock 89 crx si
ps-i have cranked it a cple times before, and right
after i cranked it, it would idle good for like a second
then the rpms would drop to 0, and it would shut
off.
Old 08-07-2003, 12:48 AM
funkdaflex1 funkdaflex1 is offline
Turn the key over once and listen for the fuel pump to turn on and to pressureize. I really think thats what your problem is.
SOLD
V
D16y8-
-Greddy Turbocharger
-Greddy front mount intercooler
-Greddy type S BOV
-Greddy profec E-01 boost control
-Apexi N1 cat back exhaust
-Tokico Hp shocks
-Eiboch Sportline springs
-AEM cam gear
-MSD spark plug wires
-Walbro 255 fuel pump
-DC sports front upper strut bar
-B&M fuel pressure regulator
-B&M fuel psi gauge
-Tenzo R Pasion 5 17" white
-Hankooks ventus hr2 tires
-eclipse and mtx speakers
-Alpine CDA-7893
-Alpine XM radio module
Old 08-08-2003, 01:03 AM
1Ballistic1 1Ballistic1 is offline
Send a message via Yahoo to 1Ballistic1
Could be anything...Check all your fuses...Check all your relays to make sure they are secure and attached... Check your starter connections....Take off the distributor cap and check for spark (Make sure your ignition coil is good and/or the module). And do what buddy said... Make sure your fuel pump is pressurizing... Could be a million things. Bottom line, spark or fuel...Unless your motor is pooched..
If it has tits or wheels, it's bound to give ya problems.
Old 08-10-2003, 03:37 PM
heathershonda heathershonda is offline
Send a message via Yahoo to heathershonda
Had the same problem with my 92 accord where the rpm would jut drop to 0. Was the coil in the distributor. Now a couple months later same problem again but this time it was the main relay. Where the car doesnt wanna turn over.
Old 08-10-2003, 03:41 PM
i finally pop started it and it has been cranking ever since. i am ging to do a b16 swap in the next week or two, so i am hoping that holds out til then lol.
