Old 08-06-2003, 07:41 PM
SiRWannabe SiRWannabe is offline
ZC running bad
my zc is running like shit, its rumbling and misfiring real bad and I'm getting a code 3,5,14,15...please help
Old 08-06-2003, 09:17 PM
jeef jeef is offline
Send a message via AIM to jeef Send a message via Yahoo to jeef
http://www.binghamtonlife.com/manual...s/91-11-26.jpg
code 3 and 5 are MAP related
14 is electronic air control and 15 is ignition output signal...
you have all the wiring hooked up right? what ecu are you using and is it a new one to you?
90- crx si w/ a D16a Vtec and a few goodies, oh and 60k miles on it heh
Old 08-07-2003, 08:31 PM
gonna double check the wiring first of all then I'm gonna check the vacum lines and if it all checks out good, gonna make a trip to the wreckers and buy the map and iac sensors, I know I should buy them new but don't got the green, I need something to make my car run better, I'm using a pm6 ecu, its new to me and it the one of the 3 I've tried to work so I'm gonna stick with that
Old 08-07-2003, 09:27 PM
would the fact that my map and iac sensors were for a dpfi setup and not a mpfi setup be the reason why they don't work?
Old 08-08-2003, 03:10 AM
HONDABOND HONDABOND is offline
No.
White folk eat noodles too.
Old 08-08-2003, 11:52 PM
I reseted my ecu and the map codes went away, so I took it for a drive and now the codes came back, so I reset the ecu again and its gone again, whats goin on??
Old 08-09-2003, 11:23 AM
it just doens't detect the problem right away drive it around and it'll prolly come back on... so have you checked the wiring and vaccum lines
Look,this is weird. Bad plugs=runs good, Good plugs=runs bad browserealty Villager 6 08-28-2007 09:05 PM
bad gas milage and runs bad tomw2 Bonneville 2 04-04-2005 08:46 AM
1996 ram 4x4 runs good runs bad Haulin Ram Pickup | Ram SRT10 1 08-30-2004 08:09 AM
