Old 08-06-2003, 01:53 PM
blade34609's Avatar
blade34609 blade34609 is offline
Mobile Mechanic
Hi,
I had a mobile mechanic come over and check out my car to see why it doesnt run. The first thing he did was get my spark plug wires in the correct firing order so it almost started.
Then he said he was gonna bypass the fuel injection system by squirting starter fluid in the intake manifold.
He did that and it almsot started by didnt.
So we took the spark plugs out and they were covered in fuel and dark black.
We then put new spark plugs in and fired it up.
Once again it almost started but couldnt.
Just coughs and sputters.
We checked the new spark plugs we just put in after cranking it awhile.
They were dark black like the other ones and covered in fuel.
Could it be how I wied the ECU?
I moved pin B2 to pin B10 so its correct.
If I didnt have B2 correctly seated in B10 what would happen?
Im pretty sure I do.
He said that I have to buy new spark plugs and leave them out along with the wires. he said let it dry out the excess fuel in the cylinders.
We cranked it without the spark plugs in and white smoke was coming out. So there must still be fuel in there.
So I have to let it dry out overnight then put my new spark plugs in.
He said it may start then.
I have a strong feeling it may be my MPFI wiring but Im pretty sure I wired it correctly.
I checked it over and over again to be sure.
Anyone got any ideas?
Thanks
1990 Honda Civic LX
5 Speed
1.5 Liter SOHC
K&N Cone Filter
APC Short Shifter
1988 Honda Civic STD Hatch
D16A6 Si swap
DX 5 Speed Tranny
90' CRX Si Gauge Cluster
Accel Performance Wires
Old 08-06-2003, 02:41 PM
blade34609's Avatar
Oh, I forgot to tell you the mechanic said that the intake manifold is blowing out instead of sucking air in. He said that is one of the reasons it wont start even when sparying starter fluid in there.
1990 Honda Civic LX
5 Speed
1.5 Liter SOHC
K&N Cone Filter
APC Short Shifter
D16A6 Si swap
DX 5 Speed Tranny
Old 08-06-2003, 02:44 PM
FourthGenHatch's Avatar
FourthGenHatch FourthGenHatch is offline
Send a message via AIM to FourthGenHatch
I have never heard of the intake blowing out air instead of sucking it in. I'd check over your wiring, I wonder if you did it backwards would the engine work the other way? I don't think so. Only thing you could screw up is when the fuel injector shoots the fuel.
http://www.fourthgenhatch.com
FOR SALE: Get this stuff out of my house!
-Stock hood (red) $30
-Stock Rear Spoiler (red) $30
-Stock mirrors $30/both
-Stock side front and rear side glass $30/piece
Old 08-06-2003, 02:48 PM
tunky tunky is offline
It might be the distributor. Did the mechanic check it?
When mine had that problem that it wanted to start but it didn't turned out to be the distributor was bad and had to replace it.
Old 08-06-2003, 03:04 PM
blade34609's Avatar
I dont think i wired it wrong.
Could the ECU be wrong?
If i didnt move pin B2 to B10 spot what would happen?
I dont think its the distributer because all spark plug wires had spark comnig out of them?
What kinda starting problem did you have that it wouldnt start and had to be replaced? Was it a cough and sputter sound like its on the verge of starting?
Thanks
1990 Honda Civic LX
5 Speed
1.5 Liter SOHC
K&N Cone Filter
APC Short Shifter
D16A6 Si swap
DX 5 Speed Tranny
Old 08-06-2003, 05:19 PM
jeef jeef is offline
Send a message via AIM to jeef Send a message via Yahoo to jeef
aight the only way you would blow out of the intake is if your cam was off by 180 degrees (of if the valves weren't sealing) and that mean that the exhaust is sucking in.... and the likely hood of that even being possible is slim to none, if the engine was running before you tired the conversion its probably a problem within your work...
90- crx si w/ a D16a Vtec and a few goodies, oh and 60k miles on it heh
Old 08-06-2003, 05:27 PM
turbcivic's Avatar
turbcivic turbcivic is offline
Sounds like your cam timing is off 180 degrees. Check your cams and crankshaft.
2007 dodge ram hemi sport-the tow/dd
1993 Civic HB-h22 with type s pistons, 125 shot, and some other goodies
1989 CRX(in the works)-h2b plus maybe some spray, or some boost
Old 08-06-2003, 08:47 PM
johnb16a2's Avatar
johnb16a2 johnb16a2 is offline
I agree, you cam timing is way off.
Old 08-06-2003, 09:51 PM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
Maybe he put the distributor back on backwards. Cuz you know how theres two prongs on the distributor that go into the cam? maybe he inserted it the wrong way which would make it exactly 180º off.
Old 08-06-2003, 10:01 PM
the cam has to be off the 180 for that, and that causes the dizzy to be off 180 it can only be inserted one way the prongs are two diff. sizes....
Old 08-06-2003, 11:57 PM
HONDABOND HONDABOND is offline
I wouldnt be surprized if this guy put the head on backwards... LOL! That would be some funny ass shit. I am sure some moron has done it before.
White folk eat noodles too.
Old 08-07-2003, 12:10 AM
Melt's Avatar
Melt Melt is offline
Send a message via AIM to Melt
yes because everyone who wires MPFI takes the head off in the process
AF Bay Area Crew
97 Toyota T100 xcab 3.4l v6 5spd 2wd
Mechanic Oil Change Mishap parkca01 Engineering/ Technical 7 01-21-2011 05:26 PM
Mechanical choices..... dazzlingfem Engineering/ Technical 3 12-16-2010 08:17 PM
1993 GMC Suburban 350 mechanical oil gauge help! jfitz0121 General Discussion 0 03-14-2010 01:27 PM
1996 Subaru Legacy Outback Mechanic? LLouise Tucson 0 03-21-2009 11:45 AM
Farkin mobile mechanics Jonno Stress Release 6 05-17-2005 08:01 AM
