Old 08-06-2003, 01:17 PM
kchampion kchampion is offline
Burnouts
Hi, i have a 66 Ford Fairlane with all 4 drum brakes. I would like to show off everyonce in a while and do a burnout or brakestand (engine doesn't have enough power to actually just burnout), however the breaks in back are activated. Anybody know a good solution so to disengage the rear brakes, but not totally disconnect them?
Thanks,
Brent
Old 08-06-2003, 04:15 PM
ChaosStarter ChaosStarter is offline
Send a message via AIM to ChaosStarter
a line-lock would prolly be the best solution for this...
1999 Pontiac Grand Prix GTP (2dr)
"Gold" Package
~drop in K&N
~3.4" pulley
~drilled 180º T-Stat
~Casper's cooling fan switch
~U-bend/Resonator removed
Best 1/4: 13.58 @ 100.17 10/25/03
Best 60': 2.07 (stock RS-A's at 30psi)
Best Dyno: 5/3/03
197.4fwhp/262.4fwtq
Coming Soon....
turbo!!
Old 08-06-2003, 04:27 PM
Is a line lock permanent or reversable?
Old 08-11-2003, 03:40 AM
Blue02R6 Blue02R6 is offline
I believe that it installs directly into the front brake line. So it would then be reversable if you replace the line.
My Stable:
2002 Yamaha YZF-R6
1988 Pontiac Fiero
1969 Pontiac Firebird
I might get my '02 SS back....
Old 10-23-2003, 11:27 PM
twinty twinty is offline
Two words : "Vice grips"
have fun!!
Old 11-29-2003, 07:18 PM
Guyanson_Mendiola's Avatar
Guyanson_Mendiola Guyanson_Mendiola is offline
Re: Burnouts
Thanks,
Brent
your engine doesn't have any power to burnout!
Old 12-24-2003, 09:37 AM
ikus ikus is offline
Re: Burnouts
open the bleeders on the back brakes,, get alot of kero put it on the road and then powerblock..
hold the brake and push the gas and watch the smoke and if your lucky the fire
Old 12-26-2003, 12:06 PM
Volvord 784VC Volvord 784VC is offline
Re: Re: Burnouts
Good joke, but don't even consider trying something this stupid.
Volvord 784VC
350HP Ford 302 Powered Volvo 740 Turbo
http://www.volvord.com New site
http://www.telusplanet.net/public/gilesij/Volvord/ Old site
Old 01-04-2004, 11:43 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
A line lock is a simple one way hydraulic valve that goes in the steel brake line to the front brakes, with a control knob mounted usually on the floor by the drivers seat. Tow trucks often have them in place of a parking brake.
Otherwise, people can soak down tires with WD40 for the same effect. However, the rear tires remain slippery for some time afterwards.
Smokey burnouts get pretty old after your first ticket from the cops or after buying two new tires, or rebuilding your differential because you seized the spider gears.
Old 02-07-2004, 08:47 PM
kratefan kratefan is offline
Re: Burnouts
Good point on the differential. If you have posi, you've GOT to spin them both equally otherwise BANG!
Jeff
Old 02-24-2004, 06:58 PM
neves neves is offline
Re: Burnouts
you should put your efforts on making the engine burn out >>> not a brakestand.... more satisfying that way
Old 03-12-2004, 11:59 PM
Dusterlover Dusterlover is offline
Re: Burnouts
I happen to agree with neves, why try to brake stand to make your car look cool when it cant even do it on its on, its pretty sad really
Old 03-20-2004, 08:13 PM
irdc019's Avatar
irdc019 irdc019 is offline
Send a message via AIM to irdc019 Send a message via MSN to irdc019
i agree with neeves and duster lover. all show and no go are for the ricers. you can boost the performance of that thing and really make peoples jaw drop.
Video - SUP CHRIS. My mustang doing a burnout... V6 Mustang Burnout 3.8L S1L1C0N onilmaruri Mustang Talk 9 10-10-2006 01:29 AM
Lets see your burnout pics. kris COMPLETELY off-topic 121 01-15-2003 10:36 PM
Burnouts Danb13 Car Videos 1 06-10-2001 09:31 PM
