Old 08-06-2003, 12:20 AM
91lxdreamer's Avatar
91lxdreamer 91lxdreamer is offline
Send a message via AIM to 91lxdreamer
Redline/Rev Limit
In my car, the redline is 6500, however, I can take it clear to 6900 and sometimes 7000 I think, it happens kinda fast and I might be mistaken. But why is the redline there if you can push it past there? Why is there the difference between the redline and fuel cutoff?
Old 08-06-2003, 01:01 AM
XxLuckyLisaxX's Avatar
XxLuckyLisaxX XxLuckyLisaxX is offline
Send a message via AIM to XxLuckyLisaxX
who knows all i care about is that i can take my si to 7200 baby
Keep it real, and share the knowledge.....
Say NO to Primer!!
Old 08-06-2003, 01:10 AM
SiZ's Avatar
SiZ SiZ is offline
Redline is where your car should be shifted if you're racing. Optimum point for most power.. Your car is likley making less power when you're running it past redline.
Fuel cutoff is becuase people aren't smart enought to shift at red, so it has to have a rev limiter so people don't float valves.
"The nympho of info, I'm fuckin' what ya heard"
Old 08-06-2003, 01:12 AM
and yes i did know that you are not supposed to take it as far as it can because at a certain point you are actually putting out less power by taking it too far, so no im not a dumb ass
Say NO to Primer!!
Old 08-06-2003, 01:29 AM
SiZ's Avatar
SiZ SiZ is offline
DE - FENCE!
No one was calling you a dumbass.. I'm saying that by taking it that far the reason it cuts is to save your motor. Answering the original question.
Old 08-06-2003, 11:43 AM
91civicDXdude's Avatar
first off the rev limit on a PM5 ECU is 6800, on a PM6 it is 7200 and on a PG7 it is 7500.
secondly, in response to shifting at redline for maximum power.... unless you have a VERY close ratio transmission, shifting at a higher rpm, although making less power at the time, would actually be faster becuase you are still making power, just less than peak, and the higher you rev, the higher rpm you will drop back in at after shifting.
Its better to rev higher and make a little less power than at peak, and then drop rigth back into the powerband at your peak torque point than it is to shift at peak power and drop below your peak torque.
Old 08-06-2003, 12:06 PM
JDM 4g4D's Avatar
JDM 4g4D JDM 4g4D is offline
Send a message via AIM to JDM 4g4D
On a b16a b17 b18c b18c5 , if you build it right it will make power up until about 9500 RPM.
My B18b was built up to make power up unitl 7500. Peak at about 7200.
And if your woried about floating valves, Try Skunk2 or Crower.
200whp ALLMOTOR CLUB
ALLMOTOR.NET
Car Photos
Old 08-06-2003, 12:23 PM
ian16v ian16v is offline
my zc has a pm7 ecu which hasnt been chipped and the limiter comes in at 7200..... although on some occasions when puttin car thru its paces the limiter wont come in til 8000rpm i shit u not! strange....
1995 Toyota Starlet GT Turbo Advance & 1991 civic b16a1 project/track car
http://www.boomspeed.com/civic16v
Old 08-06-2003, 12:24 PM
Black91si Black91si is offline
I CAN TAKE MINE TO 8000!! THE FULL RPM!!..oh yea, my ecu is chipped
ITS ME!! 91blksi!!!
Old 08-06-2003, 02:53 PM
JDM 4g4D's Avatar
my friend has a fully built b16a3 in his 97 EX.
Revs it to 11.5
TODA Internals. WHOOHOOO
Dyno'd at 215 hp to the wheels
Old 08-06-2003, 03:08 PM
[quote]Originally posted by 91civicDXdude
[b]first off the rev limit on a PM5 ECU is 6800, on a PM6 it is 7200 and on a PG7 it is 7500.
I know that this has probably been asked before, and I can slightly remember the post for it. However, what ecu is my 91 lx? I cant remember where to find it for the life of me, but I want to know for future reference.
Old 08-06-2003, 03:22 PM
SiZ's Avatar
SiZ SiZ is offline
Revs it to 11.5
TODA Internals.
11,500rpm on Todas, making 215whp?!
Not buying it without dynos. Sorry buddy.
http://www.honda-tech.com/zerothread?id=178191
Old 08-06-2003, 03:29 PM
BlueCivic83's Avatar
BlueCivic83 BlueCivic83 is offline
Send a message via AIM to BlueCivic83 Send a message via Yahoo to BlueCivic83
ok now could one of you explain exactly what hapens when the cecu cuts the fuel well i know it cuts the fuel but what hapens next? does the car die on you does it go down to the lowest rpm ??/
most of the time when i'm really going to the max right
a get to a point were the pedul is like not responding anymore and like it's not getting any gaz
but i'm never at that high an RPM why does that hapen ? what could be cauzing it ?
once i was racing this other civic and almost crashed in the behiND of this big pick up but after braking down the car did 'nt want to acelerate
Old 08-06-2003, 03:48 PM
Ive never actually done it driving, but I would imagine its basically the same as when youre just revin when sittin there. It will hit the fuel cutoff point and stop and then re-engage and hop back up to the cut off point. It should just hop up and back down over and over as long as you keep gas to it. I could be wrong, anyone else know for sure?
Old 08-06-2003, 03:51 PM
SiZ's Avatar
SiZ SiZ is offline
