Old 08-05-2003, 11:58 PM
89Stanger 89Stanger is offline
Question Little Help With Car? plz
Alright heres the deal.. i just bought my 89 mustang lx hatchback. its a 5.0 stick with only the exhast as a mod.. i think its a flowmaster offroad h-pipe or something (BTW, i dont know cars). ok the thing pulls very good however im interested in buying a turbo or supercharger. my questions would have to be... which ones better, what costs more, what would my hpwr be, and will alot of work have to be done to my stock stang in order for it to work? any advice would be very gratefull.. thanks.
Old 08-06-2003, 06:50 AM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
For you I would suggest a supercharger for the car. Easier to instal or have installed, and cheaper then going turbo. You would also have to upgrade your fuel system to accommodate the more fuel that will be used.
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
Old 08-06-2003, 12:57 PM
boosted331 boosted331 is offline
I would go with a blower for your car. You can buy a vortech S-trim kit or a procharger and they literally bolt on, save for maybe a little bit of cutting, but most turbo kits do involve cutting, welding, and some massaging of parts. For your car I would recommend a procharger kit with the P1SC or D1SC and 3 core intercooler.
Old 08-07-2003, 12:50 AM
ok so a supercharger would be easier.. but if my stang is stock.. and i make a charger work in there what will the hpwr be at? and will it be really bad for the car? (i heard chargers/turbos take avg 5 years off the cars life..)
Old 08-07-2003, 12:53 AM
hit the finish button to soon.. ok so maybe you guys can hook me up with some links for this stuff i should get.. whats your recomendation on which types to install.. and maybe an estimate on how much it is for parts/labor... just est', all i need =-) o ya and thanks for all the info so far =-)
Old 08-08-2003, 12:57 PM
With a 10 pound procharger on a basically stock mustang it should bring you up to around 300-330 RWHP, or about 110-140 RWHP over stock. Engine life isn't going to be shortened much/any if you don't go around with your foot on the floor, assuming your engine doesn't have 200 thousand miles on it already, in which case I wouldn't install a blower until you rebuild the motor. I would ditch the lousy stock FMU that comes with the kit and step up to 42 lb/hr injectors, and get a walbro GSS-317 fuel pump, and take it to a reputable tuner for a nice safe tune. Install would be around a thousand dollars, which is a total waste of money. You can do the install in your driveway with basic hand tools, a torque wrench, a bit of mechanical knowledge and some patience.
Old 08-08-2003, 02:52 PM
Sounds good man.. thanks for the info.. the car only has 60k orginal miles on it.. =-) so i think it should be safe with that charger... any types or models you recommend? if so please post any links to sites and what not.. thanks again =-)
Old 08-13-2003, 01:55 PM
fatninja19 fatninja19 is offline
Send a message via AIM to fatninja19
How much for those kits you guys mention and wheres the best place to buy them?
when in doubt, throttle.
Old 11-14-2003, 09:03 AM
oray777's Avatar
oray777 oray777 is offline
Re: Little Help With Car? plz
Hey! That's my goal too!!
Old 11-14-2003, 11:05 AM
stang_racer20's Avatar
stang_racer20 stang_racer20 is offline
Send a message via Yahoo to stang_racer20
If I were you, first I would check out the supercharger manufacturers website to see what you want or should get. Look at the stuff like Q&A sections and kit options. There are so many variables to be chosen(satin/polished, intercooled/non, boost levels, etc.), don't just point and choose! Check out www.procharger.com, www.vortechsuperchargers.com, www.paxtonauto.com. The system you will probably need should cost $3000 - $4000. Lets us know what exactly your looking for!
92 Mustang GT, 347 Stroker(Forged Steel Crank/Rods-Balanced, Forged Alum Dished Pistons), B50 Block, Track Heat Intake, Twisted Wedge Heads w/ Stage 3 port/polish, 80mm C&L MAF, FMS 30# Inj., BBK AFPR, Trick Flow Stage 2 Cam, Trick Flow 1.6R Rockers, BBK EL-CC Headers, MAC O.R. H-Pipe, Flowmaster Cat-Back, Accufab 75mm TB, MAC CAI, BBK Pulleys, Griffin Alum Radiator, Mark 8 Fan, MSD Pro-Billet Distributor; AOD, Dynamic 3300 L-U Converter, B&M Trans Cooler; 3:73 gears.
