Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 08-05-2003, 09:24 PM
sursh79 sursh79 is offline
Angry 1st to 2nd gear (thud) shift
hey guys,
so i recently had 2 fuel injectors go - 1 was bad, other was cuz of no ECU signal (car computer) to it ...i replaced injectors AND i just changed the ECU ..and engine rides smoother BUT now (immediately after changing ECU):
-- engine light came on. codes pointing to EVAP Cannister purge valve or something ..will check on that soon - but its emission related i think
-- (the car is auto not manual) when car goes from 1st to 2nd gear - it shifts REALLY hard ..like a thud and whiplash style ..2nd -to 3rd and so on is ok though..
my questions:
-- is this EVAP purge code mean anything 'serious' - i'd rather focus on solving gear-shift issue
-- how could changing the ECU / ECM affect my car shifting 1st to 2nd gear?
-- What can I check further to see why the hard gear-shift?
As always - thanks for the replies.
sursh79
Old 12-16-2003, 08:41 PM
Az4R1 Az4R1 is offline
Re: auto-max: 1st to 2nd gear (thud) shift
I have hard shifting on my 95 too... also from 1st to 2nd and, like yours, 2nd to 3rd is fine.
Did u figure out the problem?
Thanks.
Old 12-19-2003, 09:40 AM
MaxedOutOfCash MaxedOutOfCash is offline
i'm not a tranny expert but.....look into the valve body....i know that this might cause the hard shifting.....i know that auto guys put the vb mod in the car to make the car shift harder and faster.....
Old 12-24-2003, 12:04 PM
GP2K GP2K is offline
The "thud" that you experience is the burned solenoid in your tranny. Have that replaced. I've had my solenoid burn out twice on me. I have '00 GP so maybe it's the same problem with your car. Hope this helps!
Old 12-24-2003, 12:17 PM
BP2K2Max's Avatar
BP2K2Max BP2K2Max is offline
Send a message via AIM to BP2K2Max
the evap problem could be something as easy as your gas cap is on too loose. i had a code pulled at autozone cuz of a service engine light and the guy said my vacuum lines were clogged. i tightened the cap and had the guy reset the code and it never came back. i've heard the purge valve on the evap canister won't open unless there is good backpressure in the fuel lines. this is just speculation, i don't know for sure.
BP's Rides;
- 2005 Kawasaki Ninja ZX6R- Mods: ECU Jumper, Akrapovic Slip-on, Power Commander III, 8000K HID's.
- 2K2 Maxima 6 Speed-Mods: Advanced Timing, Cattman Cat-back Exhaust, H&R Springs, Tokico Illumina Struts, Konig Theory 19" Rims.
