Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Suspension
Suspension setups, shocks, springs, tires, handling.
Old 11-26-2001, 01:22 PM
CanadianG's Avatar
CanadianG CanadianG is offline
Send a message via ICQ to CanadianG Send a message via Yahoo to CanadianG
Who knows anything about 17" blades on a P10?
I had 17x8 blades on my G last week and I had to take them off my car!
They had 215/40/17 michelins. It was off my boys 99 Accord. The problem here was that my tires were rubbing against the shock tower right beneath where the spring sits. What is the proper tire size to go with cause I can get these rims for cheap but the 17" tire is gonna hurt.
Gimme some advice...........
Women call my bedroom the COCKpit!
Old 11-26-2001, 01:58 PM
G22DET's Avatar
G22DET G22DET is offline
Send a message via ICQ to G22DET Send a message via AIM to G22DET
not because of the tires but the rims...it's too wide for the P10
Luke C.
GDA Power!
Old 11-26-2001, 02:08 PM
G-Forces's Avatar
G-Forces G-Forces is offline
Banned
I think you could run a 8" wide wheel but you'll need to be 'bang' on with the offset. I have no idea what it would be either so don't ask. :silly2:
Old 11-26-2001, 02:43 PM
CanadianG's Avatar
by offset
You do mean the rim offset?
If so they do fit on my car. Its just that the tire is rubbing the inside of the tires was a little bit worn. The rear was worse than the front. Actually the fronts dont have a problem they are rubbing but there isn't any worn rubber on the tires nor is there any marks on the strut tower.
Can you put 205's on a 17x8?
and should I have a lower profile like a 35?
Old 11-26-2001, 05:02 PM
95_G20_P10's Avatar
95_G20_P10 95_G20_P10 is offline
i have 17's on my car im not sure if there 17x7 or 17x8 but u migth need lower pro tires im runin 205/45/17 and it almsot touches teh sroind cover. thats an idea
Old 11-26-2001, 05:38 PM
JustinP10's Avatar
JustinP10 JustinP10 is offline
Send a message via ICQ to JustinP10 Send a message via AIM to JustinP10 Send a message via Yahoo to JustinP10
If they rub on the strut, you may have to look into smaller tires, and/or spacers for the wheels, depending on where, and how they rub. Or maybe both?
Justin McClanahan
95 G20
15.4 @ 91.4mph (2.4 60ft )
143.7whp and 131.4 ft.lbs
Primera (10:1) Intake Cam, HS CAI, HS Header, UR Pullies, 19* Timing, ACT, Lightened Stock Flywheel, GC/AGX, Pacesetter Short Shifter, and more stuff...
Old 11-26-2001, 06:51 PM
CanadianG's Avatar
Maybe.....
I'll try and get some 205/40/17 rubbers!
