Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Audio/Security
Audio/Security car audio, security.
Old 11-26-2001, 12:19 PM
AznVirus's Avatar
AznVirus AznVirus is offline
Send a message via AIM to AznVirus
amps and speakers
i have this headunit that says it sends 40X4 on the faceplate. does this mean it sends 40 Watts for each speaker no matter what? is there a way to send less watts? cause the front speakers can only hold 2-20W RMS. the peak power handling is 80 watts. if i just use these speakers, will i blow them?
1.6 - The Underdog
GA16DE-T Club!
Old 11-26-2001, 12:29 PM
Swonder67 Swonder67 is offline
Send a message via AIM to Swonder67
the 40X4 power rating is referring to peak power. your headunit prolly puts out around 20-22 watts RMS. those speakers should be fine.
2003 Nissan Maxima SE Titanium Edition
Cattman Catback Exhaust
35% Platinum tint
Old 11-26-2001, 01:10 PM
AznVirus's Avatar
if i get an amp that says 150X2 RMS. that means its going to run at 150 constant power right? if it just says 150X2 then thats just peak power?
1.6 - The Underdog
GA16DE-T Club!
Old 11-26-2001, 01:27 PM
if the amp says 150 X 2 it means 150 max. They always give you Peak power, even though RMS is the more important one.
35% Platinum tint
Old 11-26-2001, 02:18 PM
AznVirus's Avatar
if i have substhat can handle 600W max, and the rated input power is 150W, will i be going under the rated input power if i use that 150X2? i want to get the most out of my subs.
1.6 - The Underdog
GA16DE-T Club!
Old 11-26-2001, 02:20 PM
Well, you'd be under the max wattage they can hold, but they will stilll work. the only way to increase the watts goin to them is to get another amp.
35% Platinum tint
Old 11-27-2001, 01:55 AM
Brian P's Avatar
Brian P Brian P is offline
Send a message via ICQ to Brian P Send a message via AIM to Brian P
"if i get an amp that says 150X2 RMS."
if it says RMS then it's RMS. and if it's x 2, then one would assume 150 RMS per channel, thus, 300 watts RMS of power.
Old 11-27-2001, 09:54 AM
if it says 150 X 2 RMS then yeah, thats 300 total RMS power. but if that were true, the amp would be over 1000 watts max power. Usually, when you see amps out there, they always show you peak power in big letters, and its usually a round number, like, 300 watt. To find RMS power, you put peak power through some wacky equation I can't tihnk of at the top of my head. like my head unit is 50 watt peak power, and on the head unit, it says, "50X4" but the actual RMS power is 22 watts per channel
35% Platinum tint
Old 11-27-2001, 10:08 AM
Rich's Avatar
Rich Rich is offline
Never Fear, Rich is here!
Send a message via MSN to Rich
I hope I dont get chewed out by any audiophiles for this.
To get a rough estimation of RMS power, its usuially 2/3 of the peak.
Example. A deck with 45x4 power is going to be around 30x4 RMS
Remember this is just a rough estimation that I just use when shopping for an amp and they usuially just say the peak power on them. If there are no sales persons around its close enough just to figure 2/3 as the RMS power.
Hope it helps.
My Wheels
15' Kia Soul SX 2.0L
13' GMC 1500 P/U 5.3L
Old 11-27-2001, 12:49 PM
I would say less than 2/3. more like 1/2 or lower.
35% Platinum tint
Old 11-27-2001, 01:11 PM
hybridamp's Avatar
hybridamp hybridamp is offline
Yes, usually %50 or lower.
Example: 300watt max power
would be: 150watt RMS power Typically
Though the less quality of the amp, the more the percentage goes up!
Old 11-27-2001, 01:13 PM
lloyd_nickens's Avatar
lloyd_nickens lloyd_nickens is offline
Um, if memory serves me right, the RMS power of an amp is a direct funtion of its efficiency. Take for instance my MTX 500D can produce a maximum power output of (75 amps x 14.4 V) 1080 watts. With a 91 % efficiency it puts out a real 984 watts of power. The rest is wasted as heat. Now the real trick is finding out its efficiency rating.
"God Bless BASS, What Would We Do Without It?"
"If You Can Breathe, Turn The Music Up."
Old 11-27-2001, 02:08 PM
Rich's Avatar
Originally posted by lloyd_nickens
Um, if memory serves me right, the RMS power of an amp is a direct funtion of its efficiency. Now the real trick is finding out its efficiency rating.
Yes, you are right. I just posted before because depending on the product, it can be hard to find the efficiency rating, so I figured some other way would be ok even tho its less accurate.
My Wheels
Old 11-27-2001, 02:26 PM
pche059 pche059 is offline
Send a message via ICQ to pche059
Just go with a Class D amp
anyway guys
IMHO there are not many cases that you will over power a speaker
in fact in most cases it is "underpowering" which will cause a speaker to give up.
as for worrying that too much power could be going into a speaker...well don't look at the power that they "claimed" can handle...most of the times they are unaccurate.
Just run as much clean power into it as you can...you WILL know when you are over powering a speaker... if so..you can always turn the gain down
and i would say it is still better than underpowering hence distorting the speaker
Patrick
99 Primera P11
One stripped down Primera
Old 11-27-2001, 06:26 PM
AznVirus's Avatar
well basically i want to get the best out of my speakers without blowing them. but just say your peak power on the amp is over the maximum wattage the subs can handle, it will blow if i turn it up too much right? wouldnt it be safer if i kept the peak power of the amp right at the maximum power of the subs? for example...
here is my subs...
http://cgi.ebay.com/aw-cgi/eBayISAPI...tem=1288338321
and here is an amp i want...
http://cgi.ebay.com/aw-cgi/eBayISAPI...tem=1296687752
and basically ill be running only about 75X2 RMS wattage? can i get a bigger amp without chance of blowing it?
1.6 - The Underdog
GA16DE-T Club!
