Old 08-05-2003, 09:22 AM
iceblend's Avatar
iceblend iceblend is offline
Question Removing cement
Recently i glued this part to a wrong place...Its already a few weeks old's mistake..i wonder if there's a way to remove the cement or is it the end? Btw.. i use tamiya cement.
Work In Progress
Old 08-05-2003, 09:37 AM
nervestrikes's Avatar
nervestrikes nervestrikes is offline
You could remove it then lightly sand that spot try not to take off the paint, then use tamiya compound to smooth out the paint and rewax. or repaint the small section then compound then rewax. Good luck
Old 08-07-2003, 05:05 AM
iceblend's Avatar
What i meant was removing part A from part B....not removing the cement frm the body....Sorry for the mix-up
Work In Progress
Old 08-07-2003, 05:22 AM
christofurr's Avatar
christofurr christofurr is offline
Putting the part you glued into a snap-lock bag, then placing it in the freezer for a little while will make the glue brittle, which will make it come apart easier. But still be careful when trying to remove the 2 pieces, because there's still glue there!
Old 08-10-2003, 04:48 AM
iceblend's Avatar
Hey...tried the method of putting the car in the freezer and voila it works! thnks for the advice!
Work In Progress
